Upgrading my batteries in the diamond plate tub
Verna
Member Posts: 6,876
I finally have all of the welding done (by a welder, not me) and the two 6V golf cart batteries are in place. The wiring will be done tomorrow.
Matt, the welder, first moved the diamond plate tub about 4" away from the T@B. Then he cut two slots in the bottom back support for the battery boxes to fit into. While part of the battery does hang over the back, there is not enough room for the batteries to fall out. This photo shows a black strap around the battery box. It has been replaced by a ratchet strap because the other battery box was missing the strap, on both boxes.
Here's a closer view of the slots, the battery box strap holders for the driver's side battery. The wiring shown is from the Zamp plug and a 2nd Zamp plug that I use for my ARB.
The ring for the propane tank, bolted in placed with bolts, washers and locking nuts.
The new blue ratchet straps for the battery boxes. I think I can tighten them better than the intended battery straps.
Two 232 Ah batteries, 6 volt golf cart batteries, wired in series
It gets dark quickly this time of the year. The propane tank in its ring with the two batteries on either side.
For those who don't want to cut your tub, you could forego the battery boxes and simply place the batteries next to each other.
I prefer the batteries be in a box to protect them and me. I can put my chocks inside the box, along with the foot and wheel for the tongue jack. I use those orange reusable ties so I don't lose the extras along the road.
Tomorrow....the wiring!
3
Ahhh - So that's how you did it - Cool0
Nice Job!
2007 T@B
Rockford, IL
Looks good!Norm & Pat. 320 S Outback Utah or somewhere else.
All seems to fit very nicely. Love that the tub is a bit bigger then the plastic ones as well.
Sterling, VA1 -
Very nice job!Steve and Karen Cullowhee, North Carolina 2008 Ford F150 --2018 T@B 4001
Yes, Jenn, that was my "convincing" factor. With a floor, you don't have to worry so much about losing stuff. Thank youjkjenn said:Looks great, @Verna! Do the diamond plate tubs cine with a floor in them?Verna, Columbus, IN
I hope that you will be at Tearstock so I can see it.2018 Outback S, Silver/Black - 2015 Silver Honda Pilot 4WD - Florence, KY
Nice job Verna, but it looks a little ambitious for me. I think I may go with one 155 amp battery if it will fit the unmodified tub on my Outback. Thanks for the pictures.2016 Outback.....North East N.C...... Former 2012 Silver Shadow1
Yes, John it has taken a bit of work to get to this point. More stuff to
get done in two weeks.Verna, Columbus, IN
Yea Haw! I have the wiring connected to both batteries, along with the battery cutoff switch. It works! 12.8 volts, but the switch is off for the night, no charging until I verify the in-line fuse holders I installed on the two Zamp outlets are correct. Pictures tomorrow after I dress up the wiring and put the propane tank back in the tub.Verna, Columbus, IN
- 424 Service/Maintenance & Recall Notices
