jkjenn
Member Posts: 6,417
I have been getting settled into my new T@b and have come across an issue with the TV/stereo set up. When I plug into HDMI, there is a loud hum through the stereo. I have tried a couple of different HDMI cables and do 't think that is the issue. It seems as though there is a change, although it never stops, when I wiggle to the red and black wires going into the bottom of the TV.
I know I can take it back to the dealer, but that is a 3 1/2 hour drive, each way, so if there is something I can do myself, I would like to give it a try. Any ideas?
Jenn -- My TV has red & black wires that plug into the left side of the TV near the bottom. I believe they are the cable hookups. Try unplugging them completely and unscrew the coaxial cable. Then turn your TV and stereo on to see if it still hums. If it does not hum, possibly the problem lies in the cable connection.
Maybe the plugs are not making a good connection. Try dampening the ends of the plugs (turn all power off before doing this), and then reinsert the plugs. Worth a try before spending $$ on an inline filter.
:-?Thanks, Beth and Mike. I suspect the article Mike links to is correct as the hum is limited to HDMI, and not the other inputs. My work-around is a stereo headphone cable from the HDMI device (tablet) to the Jensen stereo.
I may get a filter, eventually.
