Amazon has a "deal of the day" on the Wen generator/inverter and I might snag it. Only concern I'm grappling with is weight. I realize they're all in the 40-50 lb range. Do you think it's possible to open up the back of a pick-up truck (has a camper shell), leave the generator in there to run it? Not sure if I'd be able to lift it in/out all the time.  Thanks.
0 ·
We have added the Aluminum Platform from LG to our T@B Max S and plan to have the generator secured there and just lift down to ground and run it from there or move to where exhaust is not an issue
South Carolina
South Carolina
Ultra-Tow Hydraulic Hitch Mount Crane — 30in. - 84in. Lift Range, 1,000-Lb. Capacity
South Carolina
You could look and West Marine I believe they have a device that mounts on a railing that they use to pick up and lower outboard motors. We used one several years ago to lower our outboard down to our small tender . I believe you could attach it to one of the outboard arms on the Platform. I would still go to Camping World and try picking one of the 2000i's up first. John
South Carolina
South Carolina
South Carolina
South Carolina
Another truck bed crane idea (only $79 with their 20% discount):
http://www.harborfreight.com/12-ton-capacity-pickup-truck-crane-60732.html
http://www.jaycoowners.com/forums/f30/lifting-the-generator-and-other-heavy-items-24601.html
I am having more success of locating some non-Walmart overnight parking stops, but it would be nice to have an a/c solution for Walmart nights on really humid nights.
My truck bed has a thick rubber mat as a bed liner. The generator pulls well (gotta keep a foot on it when pulling the cord though). Even with the tonneau cover all the way folded back (it's a "BackFlip model"), the exhaust still can accumulate low in the bed. I pointed the exhaust to match the wind direction and could still smell it. Echoing or increased noise was not an issue. The genny did not move from where I put it (still locked to the bed too).
There's a wheeled cart you can buy just for the Honda 2000i. It's a cute little thing, but the handle does not fit under my tonneau cover. You can run the generator on the wheeled cart (http://www.amazon.com/gp/product/B00CSBUXJW?psc=1&redirect=true&ref_=oh_aui_detailpage_o08_s00). Still have to lift it into the truck bed though.
Quiet.... Do you know how it compares to the Honda for noise? I've heard the Honda, and it's pretty quiet, so it seems to be something of a standard.
There was a negative Amazon review stating it would not work above elevations of 7,000 feet:
21 of 25 people found the following review helpful
Seems to be an excellent inverter generator design
By David on June 16, 2015
Verified Purchase
Seems to be an excellent inverter generator design. I did have to re-gap the spark plug before it would start on one or 2 pulls as advertised. The specs called for .032 inch gap and the product came with the spark plug gapped at .028 inches. After re-setting the gap it starts easily. Now, however, I have to try and return it for a refund. Why? Well I purchased this as a source of power to go camping with. I live in the
Denver area and it runs fine here. However, the camping is in the mountains and I just learned the reason it would not start this weekend was that it can't run above 7,000 feet! We were camped at 7,500, and most places we travel with our RV are 8,000 and as high as 9,500. Westpro Systems tells me there is no replacement carburetor jet to fix this mixture issue, and therefore it's of no use to me. It would have been nice if their product information on-line, or the specifications on-line made some note of this altitude issue. If you live or play at altitude, buy something else.
Anyone know where the engine comes from, ie: who makes it?
Honda small engines and generators have had an excellent reputation for as long as I can remember, which is the justification for paying so much. It'd be great if I could find that this company (whoever this particular "Westinghouse" is now) came from good genes, as well.
I'll do some digging and see what I can find about their history in this industry.
In my current campground, 100% Honda.
2016 M@x S Sofitel - The T@bahoula
I'm sure there are some areas, particularly in utah and colorado) that you'd have to plan carefully, but in general most of west has campground areas that are located within the limitations of the generator. Would just take a little more planning to make sure there isn't an issue. Just recognize it's a potential constraint on sites and include this in your planning.
