Anyone attempted a glycol exchange on Alde?
I think it's (no discussion) because the Alde is relatively new and nobody's hit the time recommendation. 2 years seems a little short - nope, haven't looked it up - just seems to short. Does one ever have to replace the coolant in a car?0
Yeah, we have talked about it. I might be wrong, but seems as simple as draining the reservoir and adding the new. Am I over-simplifying it?Deltaboy59 said:There is much discussion on this topic, but I can't find one instance of anyone attempting this on their own or having had it done at the factory or an authorized service center...any input ? I still have about 11 months before the recommended exchange at 2 years per Alde if I am correct. My dealer is an authorized Alde rep ... Whatever that means...lol. I would prefer to perform this procedure in my own, just like winterising. Lots of good input on topping off, correct fluid, etc but still searching for that trailblazer...
Seems that it involves a bit more than that.
Alde recommends a pump be used.
Most autos recommend antifreeze replacement every 5 years...
Anyone with experience or more knowledge please chime in.
Nothing on the T@B has been as easy as draining and refilling...i.e. Winterising.0 -
Alde recommends glycol replacement every two years. That is why I'm researching info now.0
Well PXlated...you are not required to, but it is recommended, usually in the owners manual under scheduled maintenance.0 -
I know it was discussed somewhere, but Alde USA is saying if it is a high quality glycol it only needs to be replaced every 5 years.
So a car is 5 years - Wonder why such a short period for the Alde.1
Well, the Alde manual that came with my unit states every 2 years as I stated above... To inhibit corrosion.
I wonder if this gizmo will make the job that much easier...wonder how many dealers use this ?
Does T@B ship units with Alde prefilled or is that done at the dealership ?
I have read that air bubbles and vapor licks can be quite problematic without a pump/bleeder.
Anyone used the Alde app for iPhone ?
Good dealer network map if needed.0 -
That pump is over 500£! http://www.southdownsmotorcaravans.com/1900-811-filler-bleed-pump-kit-alde-spare-parts.html
My T@B was manufactured on 11/13...So my Alde is now 2 years 2 months old. If the Alde manual states that I should change the glycol every two years then I believe that I have hit the time recommendation...PXLated said:I think it's (no discussion) because the Alde is relatively new and nobody's hit the time recommendation. 2 years seems a little short - nope, haven't looked it up - just seems to short. Does one ever have to replace the coolant in a car?0 -
I think at first, we all received the British manual. The Alde materials for American units seem to be growing in their support information.Deltaboy59 said:
Bleeding the system shouldn't be too complicated and there are folks who have done that. I bleed the radiators in my house. There isn't anything to it.
Here is tne latest manual for them3010 http://www.alde.se/media/110714/v-3010-60-rev-1487-us-can.pdfDeltaboy59 said:Don't know about any British manual.
This is the USA manual that came with my unit.
If you read on page 8, k believe that changing the glycol should be quite easy. @ChanWhas previously recommended a couple of tools to check the pH of the mixture. That seems like a good idea, but we should be able to simply drain, refill the reservoir slowly, and let the automatic bleeder do its job.
I have never noticed this part in the manual before.
That "automatic bleeder" looks a lot like the air separators in my home radiant system. If so, it might not be designed to remove massive amounts of air, but just residual bits that 'separate' from the heating of the fluid. Be nice if it was for this kind of job though. Maybe we can get Ed Kauffman to confirm its function.
On our Tab's system, there is also a manual air bleeder valve in the rubber hose under the back shelf, on the passenger side. I think that would be what to use when refilling the system. Alde suggests adjusting the level of the Tab to make that bleeder the 'high point' while refilling and bleeding.
Deltaboy59, from what I've read, the alcohol level (freeze point) and the alkalinity are the important properties that need to be monitored in the coolant. Each can be measured with relatively inexpensive tools. If you find out more, I'd be interested to know about it. I tested the fluid in ours this fall and it was within the recommended specification for alkalinity. Freeze point was a little higher than I'd like, so I added a bit of 100% glycol.
It's interesting that jkjenn has found info that shows that Alde allows for a 5-year change-period with a 'good quality coolant'. I wonder where we get 'good quality coolant'! And how much it costs...Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya0 -
I think most of us would be willing to shell over a few more bucks to last another 3 years.ChanW said:
Good question.
There've been a couple threads here chewing on that very problem. You might search the forum for "glycol".
Or just go to Amazon...
From one of the previous glycol discussions - related more to topping off the reservoir - this was the recommended product ... Seirra Low Tox ... So, I'd imagine that'd work as a replacement.
I found it at an auto parts store.
I have also read on the FB tab page that some people have contacted Alde directly and received product from them. That said, I think I recall it being the Vancouver Alde office that was getting the favorable reviews for customer service, not a US one for whatever that is worth.Sally, "PlaT@Bus" 2016 T@B Sofitel Maxx-S (plata=silver; SP), previously Little Guy 2014 Silver Shadow LE, TV -- 2013 Chevy Avalanche + two hounds.0
The great thing about this thread is that "yawl" are gonna have a great solution in hand well in advance of when mine is due to be changed out.
Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0 -
Mike - Was thinking the same :-)1
I love innovation and innovative people and there is a ton of it here!PXLated said:Mike - Was thinking the same :-)
Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ1 -
Don'tjkjenn said:
"Quite easily " and "simply " seem premature from someone that hasn't attempted the exchange.If you read on page 8, k believe that changing the glycol should be quite easy. @ChanWhas previously recommended a couple of tools to check the pH of the mixture. That seems like a good idea, but we should be able to simply drain, refill the reservoir slowly, and let the automatic bleeder do its job.
My original question was... Has anyone successfully accomplished this exchange....? Wonder why the factory uses a bleeder tool if the auto bleeder takes care of this problem as you state ?0 -
Lot's of good info here... but still no answer to my original question...?0
Deltaboy59 - Not surprised that nobody's done it yet, looks like you get to be the first - Expect a complete manual when you've successfully completed the mission :-)1
i assumed that Custoner Support would provide that...but alas...0
I am not sure I understand what you are expecting to be complicated? Both the drain and fill are easily accessible. What am I missing?
