Just picked up our new baby...
1. It's 40deg outside, T@B is hooked to house 110V, turned on the heater (heat + water) to high, and after 2 hours it's only warmed up inside from 55 to 59.  Hot water works, and black hoses under the bench are warm.  Is this normal?
2. The water pump (behind the toilet/shower wall) is REALLY noisy.  Plenty of water in the fresh water tank.  Normal?
I'd ask the dealer, but they're closed until Tuesday...I may call LG tomorrow.
Thanks again for all your comments, contributions, and commeraderie!
                J.D. & Sue
0 ·
J.D. & Sue
I plan in installing a small fan near the outlet that is at the bottom of the rear bench, to force the warm air underneath out towards the front when the S is in bed mode... ...and I will be tinkering with a couple of other idea to make it work a little better this summer in prep for the fall.
Sterling, VA
J.D. & Sue
J.D. & Sue
Rebar -- If you mean the water hoses going to/from the Alde, the T-stem valves should be "in line" with the water lines to be open. If the T-stem is horizontal, the line is closed.
Here is what I did and this process worked for me. I first flushed the antifreeze from my fresh water tank. Fill the tank almost full (it holds 5 gallons) utilizing the fresh water access port outside your T@B. Slowly open your cold water faucet and turn on your water pump. The pump will force water through the lines. Run the water until it is clear. Next, turn on your hot water faucet and repeat the process. I also sanitized my fresh water tank using approx. 1 cup of bleach to a full 5 gallon tank of water. Let it sit for about an hour. You will need to repeat the draining process. By now your grey water tank will have 10 gallons in it, and you might want to dump it.
Next, hook up your city water hose. Make sure your T-stem valves are in line (open) with the water hoses. Turn on your city water at the city water connection. (I also use a water pressure regulator). Keep the water turn on and let the water circulate through your water lines for a few minutes. Repeat the draining process, turning on one faucet at a time (I also did the bathroom sink faucets.) You do not need to turn on the water pump switch this time. The pressure from the city water will fill the water lines.
Ed Kaufman instructed me to do it this way. I didn't ask why, but in thinking through all of this, there are two separate water systems; the fresh water system and the city water system. The draining and flushing using the city water will also drain the lines that are associated with the Alde. He did tell me that the black drain under the left rear (driver's side) of the T@B can be used to rapidly drain any antifreeze that has been pumped into the system, but you should still flush the lines.
So, there you go. This whole process took me several hours. It was my first time doing it, so I hope the next time I am able to do it faster. Take your time and think through the process as you are doing it.
J.D. & Sue
Paula & Larry | 2015 T@B S M@XX "Serenity"| 2014 Subaru Outback | Maple Grove, MN
Jenn -- My S model has the Alde, and there are little white plastic open and close levers, commonly referred to as T-stem valves. Look under the back seat on the floor to find the water hoses and levers. I know there are at least two of them -- maybe three??Make sure those little levers are "in line" with the hoses to allow water to flow into the lines. If you turn the lever so that it's horizontal to the line, it shuts off the water flow.
Xpadrex, I'm not sure what could be happening with your water pump. My dealer told me that once the system is pressurized, the water pump should shut off. Maybe your grey water tank is full and the water has to come out somewhere???
:(Thanks, Beth!
No worries... it'll get figured out.
Paula: I am not hooked up to city water. I thought about it, as this is the first camp I've been to that offered the option... ...but then I figured that filling the tank alone and testing it was more in line with oir typical camping realities.
TV is a 2007 Jeep Liberty. Own 2015 T@B Maxx s/wet-bath white green. St. Clair Shores, MI.
