My window screens are on the bottom with shades on top. Has anyone flipped their window screens so that the shades are on the bottom? If so, what was involved?
OutbackAZ said:My window screens are on the bottom with shades on top. Has anyone flipped their window screens so that the shades are on the bottom? If so, what was involved?
Yes, it does not work with the older styles of screen/shades, as they rely on gravity to work. it does work on the newer accordion style.ChanW said:I flipped ours, a 2014 model, and as PXL says, it's simple, but I think it depends on which year you have, as to the details.
I think they changed styles in these more recent models.
We generally care less as well. Lol. Basically, if you have the shade part way closed, and the screen the rest of the way, the screen opening would be at the top rather then the bottom, changing the angle at which people would be able to see inside.jkjenn said:OK, I am obviously, pretty slow here, how does flipping it add to privacy. If your shade is down and the screen open, even if it is at the top, can't people still see inside?
Thank you for those instructions! I will bookmark this in case I ever need to do that (sure hope not - but at least I see what tools you used). Honestly don't understand the thought process of whoever designed that - wouldn't they look down the road and ask the "what if this ever needs to be taken off" question?Dalehelman said:To get those top screws you will need tools like these plus and a 1/4" open end wench. The screws are long about 1 1/2". You can only back the screw so far with the ratchet because it hits the back of the valance. Then you need to remove the bit and use a 1/4" wench on the bit the rest of the way. Very slow going and I used my complete vocabulary of potty words. It can be done but it is hard.
Thank you. Really slow Wi-Fi signal in this LTVA BLM campgroundDalehelman said:Sorry I have reposted them.
On the flip side (no pun intended), your pup's will be less likely to see what is going on it the screen is at the top.RollingLagrima said:Another minus is if you travel with dogs who like to sit on the seats and look out the windows like mine do. If I reverse the shades I won't be able to keep them closed most of the way, leaving the bottom three or four inches open so they can peer out at the world while I try to catch a few more morning zzzzzzs.
