Hi All,
We are headed out on our second adventure with the t@b and we know that like the first, the camper will bob up and down on the road. Should we put a little bit of extra weight in the front end or it or not worry about the ups and downs?
Thanks for the advice!
0 ·
Check your tire inflation and make sure that your hitch ball is level with your receiver. On a regular T@b, the top of the hitch ball should be 16" from the ground. If both the tires and receiver are OK, it probably has to do with the way you have packed the T@b.
Do make sure the ball is at the right height so the T@B is level - As Jenn mentions, it's usually 16" to top of ball. You really shouldn't get any consistant bobing if it's level and weighted right. - On a smooth road I have to check my rear view mirror to make sure the T@B is still there - My TV is fairly heavy (Jeep Wrangler)
The 'rule of thumb' with loading your Tab is to have the tongue weight about 10-15% of the total trailer weight.
So, for example, our Tab weighs maybe 1800# empty, and around 2200# when packed. So I keep the tongue at around 220-240# when we're on the road. (I use a bathroom scale)
That said, the road we live on is terrible for bobbing. We have to keep our speed at around 25mph for the first two miles of every trip. But otherwise only on dirt roads in state forests...
(formerly a 2013 T@B Q M@X); 2015 Jeep Sahara JKU (Max Tow)
Toronto ON Canada
https://www.google.com/search?tbm=vid&hl=en&source=hp&biw=&bih=&q=trailer+sway
Good to keep in mind!
When my TV was a 2006 Rav4 (6 cyl) and I was towing the Reverse TD (900 lb dry weight), the RT would bounce horribly if I was even a few pounds over 32lb tire pressure (tires were balanced). Recommended was 35 lbs (as per sticker on tongue). I later increased tongue weight by swapping out the empty platform and the small plastic front box with a full-sized truck toolbox (I know not feasible with T@B). [Side note: The diamond-plate matched the RT beautifully! It's amazing how much you can put in one of them boxes (said with thick southern accent).]
Just a few thoughts that you've probably already considered:
The T@Bs my dealer sells have the friction anti-sway bar on the tongue that goes to the hitch (others have said they have it too - some see it as unnecessary YMMV). Do you have that adjusted properly if you have one installed?
Did you have the factory tow pkg on the Subaru? Some car company tow pkgs come with heavier alternators as well as stiffer rear suspension. If you do have the factory pkg, have you considered checking out Subaru forums to see if anyone else has had the same issue and solved it with cheap alternatives? I mention cheap because a person can install some intensely expensive suspension systems on their TVs.
Do you travel with a top rack on your new TV? Someone mentioned turbulence in another thread. I believe there's wind deflectors (some work, some don't) that can help. The forum search function is pretty good, do a search for turbulence.
Did you travel with a battery installed (probably a d'oh question cuz the breakaway-brake needs it)? Was your 20# propane tank full?
There's a good chance you were traveling with a winterized T@B, but to be honest, I towed my T@Bitha with my Rav4 all winterized and it didn't bob for the 1.5 hrs when I traveled DC metro pothole roads home (some have "Studio Apt for Rent" signs in them).
Because I did a bunch of towing of both the Reverse TD and the T@B with the Rav4 without bouncing on normal roads, I'm thinking it could be TV related (I could be totally off-base - well, I'm always off-center, but that's another thread!)
Let us know all your attempted and successful solutions!!! Someone else is bound to have or need the same information.
*hugs*
Ratkity
My T@B sits 1.5" higher than then recommended 16" with my GMC Canyon 4WD. The company that makes the 16" extra long hitch doesn't make a 5 or 6" drop that would get the T@B closer to level. I've towed the T@B over 500 miles in this configuration and there has been no sway or bobbing issues. I wanted the extra long hitch to avoid using extensions. I needed the tailgate to clear the jack when traveling with the tailgate down - I was planning on loading a motorcycle that needed the entire bed and tailgate length to fit.. It was the easiest and cheapest solution at the time.
If your spare is bolted to the underside of the T@B, I'd recommend scooting underneath to check for scrapes on the tire. It's also a good idea to try to remove the spare while under there while at home - hitched to your TV. You'll find it a tight fit (even when at 16" level and not hitched up). Now imagine doing that on a highway, with all the cookie crumbs and misc debris on the highway/road shoulder AND the T@B sitting at least 4" lower because one of its feet is flat. When someone on this forum mentioned changing the tire, I immediately went under and had high school flashbacks of holding my breath, laying on the bed to put on jeans. UGH. LOL. Space is tight! That spare got moved!! I opted for the Yakima rack - others have moved it to a tongue mount, or have put it in the T@B or TV.
tl;dr version:
My humble opinion is that if your configuration works for you, go for it. Just be careful if your spare is mounted underneath the rear.
I still haven't dealt with moving it to a new mounting, and dread the day I have to do an emergency tire change.
Edited to add: For those who don't relocate the spare, those lynx levelers or some wood blocks would be handy in a tire emergency just to get the spare off.
I appreciate the reminder that I have another use for all the blocks that we carry!
Oh, and the lug nuts that hold the spare and T@B tires might be a different size than your TV. Check before you leave home. I have a crossbar-type lug nut remover (it's really really old and I wouldn't be surprised if it fails) and a multi-sized lug nut removal tool (recommended from here).
