Is it normal to have a high-pitched sound while running the Alde on electricity only? We have a 2016 Q model, currently plugged into shore power inside our garage. The Alde sliders are set at '2' lightning bars, with the far right slider set to heat/hot water (even though we have drained the water from the lines and hot water boiler). The sound is somewhat intermittent, with occaisional momentary 'breaks'. (No regular pattern)  It only quits when I shut the boiler off by putting the far right slider (nearest the temperature control knob) to the off position, thus shutting the boiler off.  I can hear the noise from outside the camper also...I surely don't think I could stand to be inside it for very long while using the heat on electric mode only if this is normal! Surely there must be something going on/something not set correctly?
                Kelly & Roy ~ Wyoming
2016 T@B Q ~
2015 Jeep Cherokee Trailhawk
0 ·
Linden, VA
2016 T@B Q Max Outback Package - 2015 Toyota Tacoma TRD Off Road
Shenandoah Valley T@BBERS
2016 T@B Q ~
Linden, VA
Thanks for the earlier information as that is very helpful!
2016 T@B Q ~
Even though it said two, maybe it was stuck at five and by screwing with it it reset.
2016 T@B Q ~
