What to do with the textured shower glass?
jdargis
Member Posts: 305
What do most of you think of the textured glass finish on the bathroom door. We thought it was great, until the first time the bathroom was used in the trailer with the lights on, not a lot of privacy in the that little space, viewing from the outside. The glass is a lot clearer than you think! We resolved the issue by applying white contact paper on the inside surface of the glass door. Just curious?
Jeff
Jeff
After 6 weeks on the road, my wife enjoyed having the privacy, sorta of your own reading room. I guess!
(also was the main reason for buying the 2015 T@B, no exposed porta potti and they removed the sink)
I hang a scarf and a shawl that I use on cold evenings...They are held by a clip at the top of the door, so when it's time to shower, you just flip the inside fabric over the top so it doesn't get wet (2nd photo).Cheryl, 2014 Jeep Grand Cherokee Diesel, 2015 T@b S Maxx (T@bitha)2
I bought a cheapo full-length mirror to replace the glass in the shower door. The length is perfect, but I need to cut 1/2" off the width. I plan to mount it facing the living area and hope it will reflect extra light into the T@B as well as provide privacy in the shower. Plus, it lets a lady check her attire before stepping out for the day. It's one of my winter projects for PopT@B. If it works out I'll post pictures later. If not, I'll simply put the original glass back in the door frame. Sounds easy, right?
Debbie
2014 T@B S M@xx with wetbath, aka PopT@B, silver with black trim, TV 2002 Chevy Avalanche
"Take only pictures, leave only footprints."2 -
Totally agree with the privacy issue! I did the scarf thing too but I attached it like a window screen is secured to its frame. Along the top of the door is a narrow groove that I tucked a wire and the scarf into. It's nice and tight.
Dena & Jim Plano, Texas
Became Tabbers Oct. 24, 20150 -
You can hang an over the door organizer it will double as privacy and storage0
I, personally, would be reluctant to use a "cheapo" mirror instead of the glass or plastic in the shower door. A small bump can shatter the mirror creating dozens of life threatening, knife sharp pieces to fall on you.CodeJunkie said:I bought a cheapo full-length mirror to replace the glass in the shower door. The length is perfect, but I need to cut 1/2" off the width. I plan to mount it facing the living area and hope it will reflect extra light into the T@B as well as provide privacy in the shower. Plus, it lets a lady check her attire before stepping out for the day. It's one of my winter projects for PopT@B. If it works out I'll post pictures later. If not, I'll simply put the original glass back in the door frame. Sounds easy, right?
Ray and Vida Barrick
(formerly a 2013 T@B Q M@X); 2015 Jeep Sahara JKU (Max Tow)
Toronto ON Canada0 -
I'm pretty sure the shower door in ours is plastic
Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya0 -
I am planning a trip this summer with one of my sister-in-laws, so I will want to add some additional privacy, I think. I have been using the door as a towel rack and I use super long towels so it has provided a fair amount but truthfully since I have solo camped, it hasn't been an issue.
Does over the door storage reduce the width you can open the door? Does it bump into the sink/cupboard?
I sort of like the idea of contact paper.2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
Exactly how wide and tall is the glass in the door? I have some reposition able mural paper and curious if it could be used to print a photo that could be installed on the glass. I might give one a try (I' guessing it would cost about $40 to produce.0
@mash2 it is approximately 13 x 52.mash2 said:Exactly how wide and tall is the glass in the door? I have some reposition able mural paper and curious if it could be used to print a photo that could be installed on the glass. I might give one a try (I' guessing it would cost about $40 to produce.
I have been wanting to incorporate maps into my decor so I had a custom map of Yellowstone printed as a decal. It works because the bumps in the paper from the glass look like natural terrain elements. (The clock isn't staying)
6 -
I'm really liking that Jenn!
That is amazing, Jenn!! Luv it.2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0
I love the creativity! And Jenn, when I saw that clock I immediately thought of Flavor-Flav!
Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ1 -
Judy and Mike - Central KY 2014 T@B S M@X towed with Chevy Trailblazer Nights in the T@B: 321 -
Ha! Yeah, way too big for that little wall. My old clock, which I loved, won't match the new upholstery, but this black one will never do. I really like having a clock in that spot, too.
This one might work and is available via Amazon Prime. I'm thinking Velcro would hold it nicely on the wall too.
Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0 -
Liking that idea Jenn, I have a fondness for maps.
Sterling, VA1 -
I'm a nudist and don't see what all the fuss is about............just kidding HA!
2014 Wrangler Sahara & 99 Jeep 4dr Sport TV. Interests are Photography, fishing & rod building, woodworking, hotrods (73VW rat rod "DasStuka") and Camping.1 -
Jenn - just an FYI, your shower door latch is in the dangerous "UP" position. Make sure you have the emergency coat hanger in the enclosure just in case.2016 Outback 320
Ah, you are so right! I did tighten it last week after the big discussion on the getting stuck situation but will start to program myself to turn it down. Great catch! Thanks!OutbackAZ said:Jenn - just an FYI, your shower door latch is in the dangerous "UP" position. Make sure you have the emergency coat hanger in the enclosure just in case.
Nothing wrong with that! I have a couple of neighbor's two houses down that are too!TaBFan said:I'm a nudist and don't see what all the fuss is about............just kidding HA!
^^^ I see what you did there.. "catch" ...... punny. LOL2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)1
Privacy?? We been married 49 years...I vaguely remember that concept. Lol You know the honeymoon's over when she says, "Honey do you mean to sit there on that toilet and tell me ...blah,blah.""Not all those who wander are lost"- J. R. R. Tolkien
2014 T@B-S1 -
There is actually a static cling material that can be printed on by sign shops. We used it in our thermal printer. It came in clear for reverse printing and white.'17 Outback S - TV 2016 Chevy Colorado in "Colorful Colorado"1
I remember someone on one of the FB pages using a faux stained glass window film. Lots of examples at Amazon it you look for "window film".John and Henrietta, Late 2016 T@B S Max in Western New York0
Yes or look for peel and stick.Photomom said:I remember someone on one of the FB pages using a faux stained glass window film. Lots of examples at Amazon it you look for "window film".
Just remember the contours on the glass will show through. Using a thicker vynl decal and a terrain map worked in my case.2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
Your map is gorgeous. Love that it's based on a personal experience.John and Henrietta, Late 2016 T@B S Max in Western New York0
I hang an organizer over the door (one on the outside and a small one on the inside). It provides privacy and a handy place for my stuff.
Cindy with my 2015 MaxS (Puppy) and my 2015 Subaru Outback (Boo)1 -
To Photomom's comment...we have some of that stuff on our home window facing the street...got it from Home Depot.
J.D. & Sue
cbarnhill, where did you get that organizer (and smaller inside one), and how exactly attached?
2016 T@B S Max, near Portland, OR
Photo Galleries www.pbase.com/jctangney
