im trying to figure out why the Alde has stopped heating. Converter fuses seem ok. Will check Alde fuses today. I am wondering about the circulating pump. I opened up the compartment with the Alde in it and turned on the heat. There was a low humming sound. It hat likely to be the pump? Or is there sonething else I. There that might do it?
                0 ·
J.D. & Sue
Ed Kauffman would be the one. He can also tell you about what glycol to use. It should be the stuff for aluminum engines with the corrosion inhibitors, I think. Sierra is one.
Question is, where/why did it go? Why was the hose off, and is your Tab floor full of glycol now?
Alan - Amazon sells Prestone LowTox for around $28. I could not find the Sierra brand for the life of me when I was looking to top-off my reservoir. Also, you will need to dilute the anti-freeze 50% with distilled water. I'm guessing you simply add the 50/50 mixture to the reservoir to re-fill.
I contacted Prestone customer support asking if their Low Tox would mix ok with Sierra (which Ed K. said the factory uses). They thought it would be fine.
Central,Fl
2015 T@B Max-S
I had the same thing happen to my reservoir tank. here's a pic of what broke off, it leaked glycol down into the storage area. I called Ed, he sent out a replacement tank and some glycol. I had it in a few days, its a little awkward to install but got it in and everything is working fine.
Gonna have to check this.
I wonder if the stress on the tank fitting could be relieved by supporting the hose that hangs from it?
I guess we'll have to ask them what the fix is. They've been amazingly responsive to 'faulty design' problems.
The last photo shows the bend the best. It doesn't seem to be too stressed atm, but then 4.5 mag earthquake conditions of the road might cause trouble. Sorry for the slightly out of focus on the last one. Hand tremors are annoying.
The left one in your photo? It looks to be jammed against the 'flooring'.
What's Ed Kauffman suggest? He has an el that will fix it?
