We just brought our 2016 T@B Max S home, and since it is cold here in Michigan, I wanted to put a trickle charger on the battery. But I ran into a little problem right off the bat ... it appears that my battery box cover is trapped by the battery disconnect switch and wiring, which runs down through a hole drilled through the top of the cover. I can release the tabs on both sides of the cover and lift it about an inch at the back end, but that's as far as I can move it. I'm always concerned about breaking wires or loosening connections, so I don't want to get too rough with it.
I hope I'm missing something that others have already seen and solved. Any suggestions or solutions would be most appreciated. (The good news is that if I end up having to cut the cover to remove it, I think I can get a replacement battery box and cover at Menards for about $12.)
BTW, I don't really want a hole in the top of the battery cover, where water will be able to get into the battery box itself.
Here are a couple of pictures of my dilemma:
![Image: https://us.v-cdn.net/5021717/uploads/editor/hf/vpyenhog2lpw.jpg](https://us.v-cdn.net/5021717/uploads/editor/hf/vpyenhog2lpw.jpg)
If that is not possible, you may want to rewire and relocate the switch. It looks like you are eventually going to have to do that anyway.
Was this a dealer install? I didn't think Pleasant Valley was putting cut off switches in, but I could be wrong.
Sterling, VA
There are places (gaps) on the sides of the cover that are designed to route the wires out of the box. Looks like they cut the wires short, so they drilled a hole in the cover to accommodate the short wires.
This is the kind of workmanship that makes me hesitate about ever going back to the same place, even to correct their screw up.
Looks like the wires are even too short to mount the switch high enough.
Sterling, VA
I didn't really want to start disassembling and modifying a brand new camper, especially part of the electrical system, although this may well come to that. If so, your suggestions are good input. Many years ago, I became a mechanical engineer, in large part, because electricity is invisible ...
I'm going to find out if the disconnect was a dealer or factory install. I agree, it's a poor installation, either way. I'd prefer getting the dealer to fix it, so I don't void any warranties, even before our first trip.
In the meantime, I can plug into 110V in the barn. Does the battery disconnect switch in the off position totally isolate the battery from the rest of the electrical system? If so, I guess that means I should leave the disconnect switch in the on position to trickle charge the battery through the trailer's converter.
Thanks again! I'll update this discussion with whatever becomes the solution.
Rob
Chelsea, Michigan
2016 T@B Max S
You can clearly see in the photo that the lid has an entry point on the left side too and that is where the wiring comes into the battery area. Your trailer is under warranty and you could have them repair this setup or easily do it yourself if you want to eliminate having to drag the trailer back over to your dealer. I think a battery box is around $10 at Wally World.
When the dealer--or I-- end up relocating the switch and replacing the cover, it's too bad that the diamond plate will now have four unnecessary holes in it. There's evidence that the mounting screws have been siliconed, and I guess the remaining holes will eventually have to be sealed with silicone, too!
Rob
Chelsea, Michigan
2016 T@B Max S
I don't think LG ships their units with batteries - I believe that is a dealer add-on. Also, there is no way that switch and battery cover would have made it through the LG quality control process. I would strongly suggest having the dealer make the repair. This way they can't blame a future warranty issue on your fixing their mistake.
Rob
Chelsea, Michigan
2016 T@B Max S
Rob
Chelsea, Michigan
2016 T@B Max S
Some things get past quality control, maybe?
Yours is so obviously wrong, I'm surprised it got out, though.
It's good the dealer saw it as wrong too though...
And I hope my camper doesn't show up like that!
Hi Verna!
Thanks for the information that the factory has issued a technical advisory to the dealers addressing this installation. I will ask about the advisory when I take my camper back to the dealer. That an advisory exists will be good information to have in my back pocket!
Rob
Chelsea, Michigan
2016 T@B Max S
I also got a communication from a factory rep who noted that the shutoff switch is normally mounted higher up on the tub by dealers and that by doing so, this eliminates any issues of removing the battery cover, servicing the battery, etc.
The info below was sent to me from factory CEO, Scott Hubble who did communicate the prior info to the factory R&D area....
Scott replied as follows:
Good luck with your remod. You'll enjoy it when it's done!
Rob
Chelsea, Michigan
2016 T@B Max S
Edit - Replied before I saw Mike's post. Surprised that the factory isn't the one installing these.
2016 M@x S Sofitel - The T@bahoula
