I hope these photos load. Finally have time to share a few "baby" pictures. It's been fun decorating/modifying storage space, etc. More pictures to follow as I have time.
                Debbie
2014 T@B S
M@xx with wetbath, aka PopT@B, silver with black trim, TV 2002 Chevy Avalanche
"Take only pictures, leave only footprints."
Beth, the rack actually came with large suction cups, but I used very short screws to attach it directly to the wall. These are 2 short wire baskets that I found at Lowe's, then simply set them side-by-side to make one long spice rack. It doesn't hold anything heavy, and I didn't want to chance coming through the outter shell, so the short screws work very nicley and no anchors were needed. It really took some muscle though, even using a power drill, to get the holes drilled. That wall is hard stuff!
Happy camping!
2014 T@B S M@xx with wetbath, aka PopT@B, silver with black trim, TV 2002 Chevy Avalanche
Sterling, VA
Minnesota
Practicing to be a wanderer
2020 T@B 320 CSS Boondock Lite
2014 T@B 320 CSS M@xx
2020 Jeep Wrangler Unlimited 8 speed automatic
2020 Jeep Grand Cherokee Limited V8
2018 Jeep Wrangler Unlimited Rubicon 6 speed manual
Twocutes, the wire racks were in the Lowe's section where they have the shelving and storage. The toilet paper holder is one that goes over the side of the tank. Since the camper potty doesn’t have a tank, I used a 1½” square x 6” long block of balsa wood (purchased at Hobby Lobby) and notched the 1½” side to accept the metal piece that would normally hang on the tank. The TP holder hangs on the wood block, which attaches to the bathroom wall using a Command Strip. The only trick when placing the whole thing under the sink is making sure there is room to replace the TP without taking the holder down. I held it in place while removing the TP core and replacing it with a new roll before sticking it to the wall permanently.
they will not stick to anything but the bathroom mirror.
What shelf unit are you using under the sink?
Thanks
Conrad
I seasoned one of my old cast iron skillets just for the T@B
On another note, are you using the cabinet under the frig? I know we need to keep the vent clear, but I thought it is otherwise nice space.
I found an old beat up rubber coated metal one in my garage that kinda works........it is just.......really....ugly. Ah yes, vanity.
