Microwave (the sequel)
Now that I have an inverter, here is my microwave setup.  I removed the stock factory seat cushion and had a custom cushion made locally.  This is my work area with my laptop.  The microwave acts as an arm rest while clicking away on the computer.  Stays fairly hidden under the Lagun table top when not in use.  When its time for a healthy, hearty, salt-ridden processed meal, I simply move the seat cushion, plug it in and wait for the "ding."
  • CarolynCarolyn Member Posts: 128
    OutbackAZ. What kind of a microwave is that?
    2014 CS, tie-dyed exterior, "Tabula Rasa" and 2009 T@da also tie-dyed, “Grateful”
    Any idea what the power draw of the inverter and microwave are?
  • Tabaz Tabaz Member Posts: 2,379
    Here is the link on Amazon:
    http://www.amazon.com/Westinghouse-WCM660W-Counter-Microwave-Cubic/dp/B00BGTNY8O
    Also try Walmart - they may have a better price.
    This is my second one. I bought the white model but thought it stood out too much.  Like the black color much better.  No electronic clock to re-set every time you plug it in to use!
    It says 600W, but my test using a cheapie "truck stop" inverter a few weeks back had it drawing up to 900W during a five minute run.  I'll re-test it later today using my new 2,000W inverter and report back to you and Jenn.
    Bob - I have a 7 foot cable from the battery to the inverter of #4 wire.
    Bob - I have a Group 27 "dual purpose" battery. I plan on cutting the cables to as short as length as possible when I decide on a permanent location for the inverter.  What are your thoughts on running it in the propane/battery compartment with the lid cracked (the back of the compartment is open)?  One of my tech buddies says it should not be a problem.  I'm just concerned about a propane leak near an inverter, as in "BOOM!"
    Thanks for the great information Bob! The bottom of the propane tub in the Outback model is aluminum, but I can see how some debris may get in.  Covering the inverter during transit will not be a problem.  Putting the inverter in the tub will allow for much shorter battery cables and negate having to haul it in and out of the TV.  What type and size battery do you recommend?  I also have the 200W Zamp solar array if that is a factor.
    Microwave test using a 600W microwave, 2,000 Watt inverter and a white thingy with a digital readout.
    Set microwave to "High" for five minutes.  At the start of the test, micro was drawing 935W and 8.4A.  Both steadily decreased over the five minutes until ending at 862W and 7.9A.
    Ran the same test from a house outlet.  At the start of this test run, micro was drawing 950W and 8.5A.  At the end of the five minutes, 857W and 7.3A.
    Not sure what any of that means, but you technical folks can enlighten the rest of us.  BTW, never once did my 600W microwave get near 600W!  Could it be I had it set on "High?"
    We're going to teach you how to cook Frank - Am saving recipes and  taking photos - You won't need that microwave to cook frozen dinners once we're done with ya :-)
    Pxlated - that's a very kind gestrure - especially towards a total stranger. But I see no value in spending 30 minutes preparing a meal that takes me 5 minutes to eat. That's the beauty of the microwave - 5 minutes prep, 5 minutes consumption.
    There's not a meal I'm saving that takes more than ten. One pot meals Frank :-)
    Although not willing to go Frank's route, I am sympathetic. I don't like to spend my time cooking when I go camping, either.
    ST_Bob said:
    I'd bet Frank hates cleaning the pot, fork, knife and dish...  Microwave dinners = no pot, no dish.  50% savings, right Frank?
    You got it Bob.  I only use paper plates and plastic utensils.  Just lazy I guess.
    Frank/Bob - One non-stick pot, paper plates...clean up with one cup of water and a paper towel. No fuss, no muss ... Brrrrrrrp, oh my, excuse me, that was so good :-)
    Jenn - Can understand that when you're on vacation with limited time. When full-timing one tends to want the same as back when stationery.
    This is a 90+ day of vacation for me. I rarely used my plastic plates last year, so I just brought paper plates and bowls this year. Water can be a precious commodity when boondocking, so the less I wash, the better it is. I do put my foot down on having real forks, knives and spoons, silicon cooking utensils, but I don't mind using a permanent plastic spork for breakfast Cheerios.
    I do have an assortment of an imported set of microwave bowls. Easy to clean, and can be used as serving bowls, too.
    Agreed. I have started collecting extra plastic and paper when I get takeout and have been saving up. I also have a stash of plastic ware from last year. I save the water for the pots and pans and cooking utensils.
    Verna - Yep, standard metal silverware. Nothing sucks more than plastic forks & knives.
    But, of course, my handles are red ;-)
    Well of course - Wouldn't expect them to not be :-)
