Step up, or not
Alan
Alan Member Posts: 120
looking at the many wonderful T@B pictures I find that some people rely on the pull out step into the camper while others have an independent step for that purpose. Is there an issue with the step provided by the manufacturer?
  • Cyclonic
    Cyclonic Member Posts: 1,232
    The older Dutchman T@B's do not have the pull out step, that is probably where you are seeing the difference.
    Sterling, VA
  • Verna
    Verna Member Posts: 6,876
    Sunny Day, my Shih Tzu, is not a good jumper. After her bruising her rear knee bad enough for me to take her to the vet, I gave up on the pull-out step and I use an aluminum step that is about 18" x 20" or so. She's happy and it was a lot cheaper than vet bills.
  • Nomad
    Nomad Member Posts: 7,209
    Pull out step works fine for me.
  • jkjenn
    jkjenn Member Posts: 6,424
    Rocky is a really great jumper, but he won't even try, lol.
  • Nomad
    He's got ya suckered with cuteness Jenn - I wouldn't jump either if momma would lift me instead ;-)
  • jkjenn
    This is true.
  • sabel
    sabel Member Posts: 283
    We have a screen room which needs a seperate step so always bring the plastic stool. Also need it to access stuff on the roof rack. Also a bit easier to use than the fold-out steps. I too weigh 410 lbs.
  • Mouseketab
    Mouseketab Member Posts: 1,262
    Even with the LG T@Bs if you set up the full screen room, it blocks the pull out step, so you need an extra step. Also, if you have a site that you have to raise the front to level, you might want that extra step.
    Carol
    MOUSE-KE-T@B
    2022 nuCamp T@B 320 CS-S
    Harvest, AL
  • RollingLagrima
    RollingLagrima Member Posts: 435
    edited April 2016
    Anybody able to measure the width of the standard LG step for me?
  • JandJ92010
    JandJ92010 Member Posts: 304
    It's a standard RV step, 8" deep, 20" wide. 8" from the ground when out, and about 10" from the step to the threshold. Sticks out about 10" when deployed.
  • RollingLagrima
    Excellent, thanks JandJ!
