Step up, or not
Alan
Member Posts: 120
looking at the many wonderful T@B pictures I find that some people rely on the pull out step into the camper while others have an independent step for that purpose. Is there an issue with the step provided by the manufacturer?
The older Dutchman T@B's do not have the pull out step, that is probably where you are seeing the difference.
Sterling, VA0 -
Sunny Day, my Shih Tzu, is not a good jumper. After her bruising her rear knee bad enough for me to take her to the vet, I gave up on the pull-out step and I use an aluminum step that is about 18" x 20" or so. She's happy and it was a lot cheaper than vet bills.Verna, Columbus, IN
Pull out step works fine for me.0
Rocky is a really great jumper, but he won't even try, lol.Verna said:Sunny Day, my Shih Tzu, is not a good jumper. After her bruising her rear knee bad enough for me to take her to the vet, I gave up on the pull-out step and I use an aluminum step that is about 18" x 20" or so. She's happy and it was a lot cheaper than vet bills.
3 -
He's got ya suckered with cuteness Jenn - I wouldn't jump either if momma would lift me instead ;-)0
This is true.PXLated said:He's got ya suckered with cuteness Jenn - I wouldn't jump either if momma would lift me instead ;-)
We have a screen room which needs a seperate step so always bring the plastic stool. Also need it to access stuff on the roof rack. Also a bit easier to use than the fold-out steps. I too weigh 410 lbs.0
Even with the LG T@Bs if you set up the full screen room, it blocks the pull out step, so you need an extra step. Also, if you have a site that you have to raise the front to level, you might want that extra step.Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL0 -
Anybody able to measure the width of the standard LG step for me?Sally, "PlaT@Bus" 2016 T@B Sofitel Maxx-S (plata=silver; SP), previously Little Guy 2014 Silver Shadow LE, TV -- 2013 Chevy Avalanche + two hounds.0
It's a standard RV step, 8" deep, 20" wide. 8" from the ground when out, and about 10" from the step to the threshold. Sticks out about 10" when deployed.The HobbiT@B, 2015-L, towed by a2014 RAM C/V0
Excellent, thanks JandJ!Sally, "PlaT@Bus" 2016 T@B Sofitel Maxx-S (plata=silver; SP), previously Little Guy 2014 Silver Shadow LE, TV -- 2013 Chevy Avalanche + two hounds.0
- 968 Air Conditioning & Refrigeration
