Rhino sewer hose
while "practicing" using the Rhino sewer hose everything was going fine until I was removing it from the T@B drain. At that point the plastic piece that attaches to the camper came off! I think I can just screw it back on, but am wondering if there is some adhesive that's missing? I certainly don't want this to happen when I'm draining something other that clean practice water.
    Yuk indeed...I don't think my Rhino end piece can unscrew (I've wanted to do that for storage), so I'd check where you bought it or, as you suggest, put some adhesive on...maybe adhesive silicone caulk.
    J.D. & Sue
    I didn't have this happen, but I did notice that mine had wiggled loose, once. I don't know that you need to add any adhesive but it might make you feel better. What a yucky thing to have happen!
  • AlanAlan Member Posts: 120
    I think you got it, Bobbo! I hadn't noticed the locking ring information: left-lock, right-unlock.
  • charliebortoncharlieborton Member Posts: 4
    Is 15' a long enough sewer hose?
    A 10 footer would be adequate in 90% of the dumps I've been thru so 15 should have you covered.
