I am hoping to solo camp with the T@B and my two dogs. A friend and I took the T@B on its maiden voyage this past weekend and found that we do need two people to position/reposition the T@B, unless it's on an absolutely flat surface, which is rare. For those that solo camp, would you please share some of your tips on how to ensure a safe (no T@B roll aways!) and fun trip? Thanks in advance!
Beth
Minnesota
Practicing to be a wanderer
2020 T@B 320 CSS Boondock Lite
2014 T@B 320 CSS M@xx2020 Jeep Wrangler Unlimited 8 speed automatic
2020 Jeep Grand Cherokee Limited V82018 Jeep Wrangler Unlimited Rubicon 6 speed manual0 ·
TV is a 2007 Jeep Liberty. Own 2015 T@B Maxx s/wet-bath white green. St. Clair Shores, MI.
Minnesota
Hi, Beth2 -- Put the Lego-type levelers under the tires (other T@BBers use the BAL leveler). The crank stabilizers are only used to "stabilize" the T@B. I bought a pack of 8 yellow plastic leveler blocks at Camping World. Here's a link to a similar thread in which Michigan Mike posted a video of how to use the leveling blocks. I was clueless!!!!
http://tab-rv.com/community/#/discussion/11/lego-style-levelers/p1
I use a BAL Leveler instead of the Lego blocks. It acts as a choke for the T@b, too!
I think keeping things simple some of he best advice a solo camper can follow.
Never try to lift the trailer with the stabilizers. They are not made to handle the load and you may damage them or your trailer. The stabilizers are meant to only stabilize the trailer once it is finally positioned. In other words, just enough contact with the ground to make the trailer stable.
I have made many mistakes while parking, unhooking, leaving, etc. Luckily none of them have been catastrophic. Take your time. Don't let anything or anyone rattle you or rush you. Check everything twice before proceeding.
The most important thing in preventing a runaway is to be sure your wheels, both sides, are chocked before unhooking. After chocking, unhook your tongue, your chains AND your cord (breakaway brake as well) before pulling away slowly. Check twice, Check twice. Check twice. Three times won't hurt either.
Happy Trails Y'all
I have a T@B Q Maxx, with the couch in the back. I kept the couch down and a memory foam mattress set up on that (I'll do the same at Atwood since my Becky will not be joining me), kept the table up, so I have the full set up without moving things every time I move. Simple meals make for quick and easy prep and cleanup.
I also have the mentioned BAL Leveler. This is a great investment, makes leveling a breeze and also acts as a chock. You simple place the trailer where you want, use the leveler to get the side to side level, chock the other wheel, unhitch and use the tongue jack to get the front to back level. Pull away and drop the stabilizers (I made an adapter so I can use a cordless power drill). Setup takes about five minutes if I am boondocking, slightly longer for hook-ups.
Sterling, VA
Minnesota
With the blocks you figure out where you want the trailer and see how far off level you are. Pull the trailer forward some and then build the blocks up to a height that would level the trailer when it sits on them. Back the trailer up on to them, chock the wheels and unhitch.
With the BAL Leveler you put the trailer where you want. The leveler slides in under the trailer wheel from the side. You use an included wrench to ratchet a screw jack that lifts the leveler into the wheel and then lifts the wheel up. Ratchet it until the trailer is level, chock the other wheel, unhitch and you are done. Very easy and the screw jack is not difficult to ratchet up.
Sterling, VA
Minnesota
