I am making arrangements with a trailer shop to get my SUV ready to pull the T@B. I'm having trouble making him understand what I want in terms of a battery isolator - i.e. a relay or solenoid device that cuts power to the charging line when the ignition switch is off.
He called today and wanted to know if we wanted the "switch" inside the cab or under the hood. This tells me that he has no familiarity with this kind of device. He finally had me email him a picture of one.
How many people have one of these things on their tow vehicle? I was under the impression that people would have them as a matter of course and it would be no biggie to get one installed.
0 ·
And not this:
http://www.amazon.com/Stinger-SGP32-Battery-Relay-Isolator/dp/B001HBYXVS/ref=sr_1_3?s=automotive&ie=UTF8&qid=1459249921&sr=1-3&keywords=Battery+isolator
My TV came with a factory hitch and harness, but my impression is that vehicles with this option already have the infrastructure in place so that installing the harness (and its associated fuses and relays) is plug and play (assuming you know where and what to plug...).
I'm guessing a regular shop may resort to just splicing wires into your existing TV harness. No reason that can't work, but an OEM installation is likely to be more reliable and elegant. Of course, you'll pay for that advantage if a dealer does the work.
Back to your original question. My OEM trailer wiring cuts the power to the T@B battery when the engine is off. This may not apply to your particular vehicle, so be sure to ask the right questions if you go this route.
Taking it in to Trailer Place #1 tomorrow and we'll keep our fingers crossed.
Do you have a volt ohm meter to verify whether the 7-pin connector is wired through the battery isolator? If there is no power at the 7-pin connector with the ignition turned off, then you don't need an additional battery isolator.
If you have power all the time on your 7-pin connector, you just need the wiring rewired to Toyota specs so the 7-pin connector is off when the ignition is off.
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
find out it was a Toyota.
They are are working on the car as I write this. We decided to hold off on the battery isolator for now. Our first real road trip won't be until late July so we've got time to figure it out. The trailer guy is going to leave some extra wire so an isolator can be added later. I might talk to the dealer next time I have the car in for service and get their recommendation.
