Hi! I need some advice with a repair. 2005 DM, the sink drain is leaking right at the drain/sink gasket. Don't want to break something by being too ham handed with a wrench. Tried tightening, but didn't help. Tried taking off, but it didn't turn easily.
Any thoughts? Any repair docs?
                Lazuli Bunting from Utah
2005 Dutchman T@B & 2010 Toyota 4Runner
0 ·
Thanks, Ratkity, I often forget about the little things like that.
The drain is a very simple, very compact thing. The P trap is two parts, connected together with a single screw. The sink drain basket threads to the upper section of the P trap. It all came apart quite easily. There did not appear to ever have been any plumbers putty under the strainer edges. The black gasket which sits on top of the upper P trap piece was in very good condition, no cracks or splits. I put it back on. I cleaned all the parts very well, put a small rope of plumbers putty around the sink drain hole before putting the basket back in the hole.Threaded it all back together, tightened gently with a wrench, since it's all plastic. After letting the putty dry for a few hours, I poured a couple gallons of water in the sink, sat on the floor and watched inside the cupboard.
Yay, no drips!
Maybe it was just grime??
