Shower door magnetic strip
judymacjudymac Member Posts: 403
Found 1 discussion in the files and it was a complaint regarding the shower door magnetic strip.
Ours has a cut near the bottom and the lip of the strip frequently falls out which allows the entire strip to do the same.
Has anyone else experienced this?  If so, did you glue the 2 pieces?
It is such a tiny piece that a person could easily dispose as trash on the floor.
Thank you.
  • Tabaz Tabaz Member Posts: 2,375
    I had the same problem after taking delivery.  I drilled a very small starter hole at the bottom of the door just below the magnetic strip.  Put a small screw in to keep the strip from falling down.  No issues in five months of use.
