Bought a used 2014 tab.  Can't for the life of us figure out alde and hot water.  Control panel is not digital.  Recognize the rightmost lever is hit water only, hit water heat, off.  Mike is electric or propane. Left is little flames.  Assume flames anoint of heat  ?  Also right knob level 1 thru 5. 5 is highest level but of what ? Control panel does not light up.  Checked fuses. Ok.  Where is stupid hot water mixing valve? No documentation anywhere.   Thought we could figure this out, but may need to go to the dealer
                0 ·
I hope that helps.
Slider #1 (left) - Two lightning bolts
Slider #2 (middle) - Flame
Slider #3 (right) - Water/Heat (middle position)
Dial - To the little circle - This will probable get to warm but it's a start.
A few seconds after setting these you should hear the Alde cycle up - it's subtle, not loud.
Depending on the air temp inside the T@B, you may need to crank the dial up beyond the little circle
With the standard analog panel, nothing lights up unless you're out of propane, then a little red light comes on.
On a 2014, there isn't a hot/cold mixing valve - Think that was added to 2016 models.
There is a manual you can download - Sorry, don't have a link - Try the resource area to the right or search for "Alde Manual" or just "Manual"
Question, did you check the two glass fuses on the Alde unit itself?
http://www.alde.se/media/110714/v-3010-60-rev-1487-us-can.pdf
Note that the light on the analog panel should not be on under normal circumstances. It comes on to indicate certain problems (also described in the manual).
J.D. & Sue
J.D. & Sue
We are about ready to dewinterize (ugh, Michigan weather) and I know this won't be an issue, but for future reference it would be handy to know. Thanks.
Maybe one of our more experienced members might take on the thankless chore of creating a manual for the T@B to help all us newbies. I know I just completed the second right of passage of T@B ownership (the first being unable to work the Alde), I killed my battery! If you guys were not here, I think I would be pretty discouraged.
A link is in this discussion.
