i know there are many recent and soon to beT@B owners. Sweet Pegaleen and I are interested in any walk though list you may have made to bring to your dealer to insure you got a full education. Also, what do you wish you had learned? We're hoping to pick up D@isy ( yeah, I know...but it was a concession to SP) early next week. Thanks, Bill & Sweet Pegaleen
0 ·
Connecting/disconnecting the T@b from your TV,
Doing different things on the Alde -maybe shoot a video,
Opening and closing the windows,
Show you where the battery fuse is,
Show you how to get sound through the Jensen speakers from thee TV,
Helping you determine if your TV is charging your T@b, if you don't know, and
If you have the old table, how to raise and lower it.
Also, I had them turn on the fridge on LP and fire up the Alden before I arrived and tested the a/c and fan before I left. It was about a 3.5 hr drive to the dealer for me, so I wanted to make sure everything worked. It might be a good idea to camp near your dealer the first night so if you have questions or issues you are close.
winterizing and dewinterizing
lighting the fridge on propane
glycol
the hidden fuses on the Alde
J.D. & Sue
Run water through the sink and shower (if you have one) using both water in the tank and a fresh water source
Flush the toilet if you have one
Dump the clean water out of the tanks you just ran water through
Use YOUR power cord instead of the one attached to the building in their prep area
Spray it down with water and crawl around inside
Close up all windows, have someone sit inside in the dark and shine a flashlight on all seams (where roof meets sides, where floor meets sides, wheel wells, etc).
If light comes through fill the holes.
Check all systems on both power and battery and propane (if applicable)
Check all plugs (110, 12V, and USB)
Check all lights
Check window latches
Check window shades
Open and shut every cabinet and storage space
Check trim fit and screws
check door/hatch locks
look at all sides of cushions for bad sewing, etc.
run overhead fan in both directions all speeds
run A/C, heat, hot water
check tire lug nuts
crawl underneath and do a general look at the frame for anything that looks "off"
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
2017 S Max
2016 Subaru Outback
MOUSE-KE-T@B
Harvest, AL
2017 t@b CS, silver with green trim.
TV: 2017 Honda Ridgeline.
I'll add Zout to my walkthrough request. (must provide a spray bottle!!)
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
I'm going to add some keywords here so that others searching for what the dealer should do before sale will find this thread more easily.
Dealer checklist, Dealer check list, Dealer walk through, Dealer walkthrough, Dealer walk-through, Dealer punch list. Buyer checklist for dealer.
