Vinyl Graphic Cost
Cyclonic
Member Posts: 1,232
Anyone that has added vinyl graphics to their T@B, what was the ballpark cost?
I got an estimate today to add one to the back, a 54"x54" area, that I think was very high at nearly $500. Am I just expecting too much, or was that really high?
Sterling, VA
@Cyclonic, all one piece or strips? Is it vinyl with an image printed on it or just cut? If printed, more than one color?'17 Outback S - TV 2016 Chevy Colorado in "Colorful Colorado"0
It all depends. Was that the charge for the decal plus installation? Was it custom or off the shelf?
It would be a custom graphic, one color, with text. Installation was extra.
Sterling, VA0 -
I got mine for abt $50 (online) and install a bit more at $80. Only time will tell how long it lasts.Michele, Tucson, AZ. TV - '13 F150 & '16 T@Bitha special order.
You never really travel alone. The world is full of friends waiting to get to know you!0 -
Yeah, if you do the graphic work yourself, you can save some money.mickietucs said:I got mine for abt $50 (online) and install a bit more at $80. Only time will tell how long it lasts.
I bought a couple of rolls of vinyl and I have good friend with a vinyl cutter. Less than $50. Installation is easy. Saturate the area with Windex, then apply the vinyl. That gives you some working time room. Spread out the bubbles with a credit card, then let it sit in the sun for several hours (or if stored inside, for several days), then remove the masking.
Mine are not printed, just solid.Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL0 -
I just wanted some words and added the palm tree so pretty simple.jkjenn said:
Yeah, if you do the graphic work yourself, you can save some money.mickietucs said:I got mine for abt $50 (online) and install a bit more at $80. Only time will tell how long it lasts.Michele, Tucson, AZ. TV - '13 F150 & '16 T@Bitha special order.
Used to own a sign business. Really high for simple cut and masked graphics. For that size cut and masked, one color, not more than $200. A Graphic that size can be a bit tricky to install, but if you brought the trailer to the shop, maybe $75 a $100 to install. I had a smaller plotter but would have been easy to piece together the palm. There are clear sprays that provide more of a UV protection to keep the color from fading as quickly.'17 Outback S - TV 2016 Chevy Colorado in "Colorful Colorado"0
Thanks for the input guys. I've got a co-worker with a friend that owns a sign shop, going to see what kind of quote he gives me.
Sterling, VA0
- 920 Introductions
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
- 54 üCamp Rally - News & Information
