First of all, hello fellow T@B owners!
I just purchased a RENOGY 100W suitcase solar kit With controller. I would like to use the ZAMP fitting going into the battery compartment. I have located a ZAMP adapter cord to fit. My question is this.. Can I cut the alligator clamps off and simply install the ZAMP adapter?
Second question is, where can I find a socket to use on my cordless drill for the stabilizer feet?
0 ·
And, we do have a search up on the upper right of this page. One word searches do best, but I sure couldn't remember that the socket was called a "t-slot for scissor jacks"!
http://www.amazon.com/dp/B00MYDR15I/ref=twister_B00MXFE0E2?_encoding=UTF8&psc=1
As an added bonus, I spliced the unused end of the SAE cable onto the original Renogy battery clamps so I can still use those if needed. I don't recall which end I spliced where, but as Verna suggested, it shouldn't be too hard to verify which wire is which.
Make sure you splice the SAE connector downstream of the 10amp fuse included in the Renogy harness.
You may find that the the heavier 10AWG wire is harder to splice, but electrically it will work fine.
