Best of luck in your research! We see them at Costco fairly often for just under $500. We are tempted to buy one each time we see them! Not sure how they are, but the ratings seem good.Mr_Mrs_Gnome said:Has anyone seen/tried the new Generac iQ2000 : http://www.generacmobileproducts.com/products/portable/products/iq2000-portable-inverter-generator
ST_Bob said:Solar is enhanced by altitude. Solar panels work better as there's less air between the sun and the panels. The lower temperatures as you climb also increase efficiency. Keep going - by the time you get to low Earth orbit you'll have enough excess power from the panels to really do something. You won't be alive though due to the lack of air pressure
Gets really cold up there though.ChanW said:I dunno, the Tab is pretty air tight. It might keep the atmospheric pressure required for survival up there.ST_Bob said:Solar is enhanced by altitude. Solar panels work better as there's less air between the sun and the panels. The lower temperatures as you climb also increase efficiency. Keep going - by the time you get to low Earth orbit you'll have enough excess power from the panels to really do something. You won't be alive though due to the lack of air pressure
