Prodigy P2
Factory tow package
1 successful trip 3 months ago
2015 t@b
15 minutes into our 2nd trip today controller switched to NC, intermittently comes back for short periods at first but stopped doing that.
Stopped at my car mechanic, they checked 7 pin with volt meter, fuses under hood, checked relay box under t@b. Nothing obvious. All lights working so continuing 4 day trip. Xterra stops good without trailer brakes so wasn't worried.
Now the weird part. Electric brakes are definitely engaging both with brake pedal and manual lever. Can change boost but not number setting.
1 year old trailer, cleaned the 7 pins good tonight but no change. Next guess is brake magnets? Probably taking it to a trailer shop next week. Friday the 13th came early for me I guess.
Anybody have this gremlin?
2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 620
0 ·
By the way, the brake wire in the seven pin will show a current. Gotta test resistance. Don't know enough about voltmeters to know if you can test your controller with one. I used a circuit tester with an incadesent bulb to test if it was my controller. Bulb glows brighter as you apply the brakes. And glows not at all otherwise.
"Weirdly engaging..." Hmmm, I've been described that way. :-)
I've never had electrically-operated trailer brakes, but that sure is different from the understanding I had of how they worked 50 years ago; cool!
A strong signal (really hitting the brakes) might send a very rapid series of pulses, spaced closely together, where light pressure on brakes would send more widely spaced signals to the actuator-- at least that's my take on it.
If I'm remembering correctly, I think older electric brake systems did use resistance- essentially a very large potentiometer attached to the brake pedal that would vary voltage, most likely, to the actuator. Really old school!
See article: https://en.wikipedia.org/wiki/Pulse-density_modulation
No brake, no glow - Slight brake, slight glow - Hard brake, bright glow.
J.D. & Sue
PXL, I suspect the reason you don't see pulsing in the bulb itself is because even "slow" pulses occur quickly enough that the incandescent filament doesn't have time to cool in between. If I understand it correctly, faster switching delivers voltage more frequently, and causes the bulb filament to glow a little brighter overall.
Now that I think about it, my lower-end Tekonsha Voyager controller has an indicator light that glows with varying intensity depending on how hard the brakes are applied. In thinking it might work the same way as that test light.
I did some web research on electric trailer brakes, and, as usual, found umpteen explanations of the "benefits," but no detailed explanation of exactly how they work, i.e., what sort of analog-to-digital system they use (if they use that at all-- but I'm betting they do!). It was my guess that current systems use PWM technology, but I have yet to learn what's actually used.
And yes, an incandescent bulb would show brighter/dimmer in a PWM/PDM situation, whereas a typical TVOM (voltmeter) would only show a presence --or not-- of 12VDC.
Amazing how technological innovations find themselves in vastly different applications!
