Ideas for covering my generator?
WildRumpus
Member Posts: 46
I will be boondocking this weekend and it will definitely rain. I have a Westinghouse WH2000 generator that I plan to run for the AC and charging, so I'm wondering if anyone has thought of a creative solution for covering a small generator to protect it from the rain? Obviously I can put it under the 10x10 canopy that I will have next to the camper, but what if I want the fumes and noise further away? I thought of a big beach umbrella, but a strong wind could blow it away. Before I begin some crazy fabrication project out of PVC pipe and tarp, I thought I'd see if any of you creative people have already tackled this problem. My requirements are: lightweight, waterproof, easy to install, and won't restrict air flow. Easy, right?
Gainesville, FL
_____________________________
2016 CSS 320
2022 Tab 400 Boondock
2021 BMW X5 45e Plug In Hybrid
2016 CSS 320
Why not a small tarp and some type of stakes?
How about a $7 plastic large bin from Walmart. Just cut out vent area.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio2
I found this aluminum folding table on Amazon for $33 (http://www.amazon.com/Outsunny-Aluminum-Carrying-23-5-Inch-17-5-Inch/dp/B00DDYE5EC/ref=pd_sim_sbs_196_1?ie=UTF8&dpID=31kAqsVEeoL&dpSrc=sims&preST=_AC_UL160_SR160,160_&refRID=1QK79P5EMZ3WKGBGWDVW). The size is perfect, especially since there are two height options with the legs. Since the top is some sort of laminated board, I could make a cover out of a piece of tarp that hangs down low enough to provide some side shelter but high enough not to restrict airflow. Guess I answered my own post! If it works I'll post pics.
Gainesville, FL
2016 CSS 320
Great idea Sam. Sometimes I overthink things and overlook the most simple (cheapest) solution. I could even stake down a plastic bin if needed.
Gainesville, FL
2016 CSS 320
I just tuck mine under the T@B tail. Asked a buddy in the construction trade that has several Hondas about rain and he runs his on sites sitting out with no protection all the time. No ill effects I've noticed after 20 months.0
Before I got mine on wheels, I used to transport it in a plastic bin. Why not just take the top off the bin, flip the bin upside down and put in on over the top of the generator? Or, cut the bottom off the bin, slide it over the gen. Then it just looks like any other bin sitting next to the trailer.Allie
Condo A-Go-Go
2017 Tacoma (AH GOGO)
S. UTAH0 -
I like that table, though. I am in the market for something that hubby, who is a die hard cook, can chop and dice on a steady surface.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Google GenTent. Pricey but good.0
Do you think the plastic bin will amplify the noise? The neighbors may not like that.Verna, Columbus, IN
It would be interesting to see if the noise is amplified. Or maybe it will be muffled! I bet if I glued some of that egg crate foam matress material to the sides it could actually be more of a muffler. But heat could become an issue. I'm glad to hear that someone has run a Honda in the rain with no problems. Still seems like a good idea to keep it dry though.Gainesville, FL
2016 CSS 320
About the only time I run the generator is in rain - If it's sunny, solar does the trick.0
Search YouTube for videos on "How to quiet a portable generator" or "portable generator enclosures." I remember finding several videos with some clever enclosures.2016 Outback 320
Won't plastic melt from the heat of the generator?
Woul think so if the exhaust is anywhere near the plastic.0
- 920 Introductions
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
- 54 üCamp Rally - News & Information
