A question about storage under the rear sofa - MY SOLUTION!
It occured to me that I might be able to cut a piece of 1/8" plywood to rest on top of the boards you can see along the walls and in the middle. I could put my bedding on top of that to keep it off the tire and other stuff.
Has anyone done anything like that?
Some of us had our Alde reservoirs leak. I had a comforter under the seat on the driver's side. Went to make the bed only to find the comforter wet with Alde fluid. I now use Costco 33 gallon bags for all my bedding that goes behind the bench seat. BTW, the dry cleaning bill was almost as much as a new comforter.2016 Outback 320
I've pondered the same project. My impression was that the additional thickness of the plywood (1/4" minimum) might impede laying the back bench flat, and possibly damage the hinges.
Not that it's not a good idea, just that you would have to recess the panel(s) somehow so they don't add to the height of the frame.
Good point. Maybe I'll use plastic bags for now. It is too big a space to leave unused.John and Henrietta, Late 2016 T@B S Max in Western New York0
Can a plastic bin be found to fit? If one is found that fits the length and width dimensions, but is too high, it can be cut down.Allie
Condo A-Go-Go
2017 Tacoma (AH GOGO)
S. UTAH1 -
@Photomom, I use either those XXXL Ziplock bags or a space bag for my sleeping bag, winter parka, etc. I had the same thought about not wanting to clean or wash if there was a leak.Verna, Columbus, IN
I have three of those canvas covered bins (roughly a foot cubed each) and store canned goods etc under there.1
How do you reach it? Do you only put it on the passenger side?PXLated said:I have three of those canvas covered bins (roughly a foot cubed each) and store canned goods etc under there.2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
Jen, I had 4 of those cubes under the passenger side rear seat. It worked well.jkjenn said:
How do you reach it? Do you only put it on the passenger side?PXLated said:I have three of those canvas covered bins (roughly a foot cubed each) and store canned goods etc under there.Verna, Columbus, IN
Thanks, @Verna . I have been considering those cubes, but not yet pulled the trigger.
I am going to put a suitcase with work clothes in the far back behind the Alde. I might put it in a giant Ziplock or elevate it an inch or two.2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
@jkjenn, I know you're taller than me, but check first to make sure you can pick up the Ziplock since it's such a long reach. A reaching clamp (whatever you call those things that you operate two clamps to pick up something) sure comes in handy.jkjenn said:Thanks, @Verna . I have been considering those cubes, but not yet pulled the trigger.
I am going to put a suitcase with work clothes in the far back behind the Alde. I might put it in a giant Ziplock or elevate it an inch or two.Verna, Columbus, IN
Thanks, @Verna . I will probably put a rope through the handles. I am tall enough to reach, but that angle makes it easy to pinch a nerve in your neck.
2 -
We had the some idea, Photomom, but the bench wouldn't lay flat. It is amazing how much storage space there is back there. You never know what you might find.
Mia Hamilton, Ontario, Canada. 2015 T@B U, formerly 2012 LG 5-Wide Platform8 -
Jenn - Yep, just the passenger side. Sleeping stuff goes behind the upright bench - easy to pull out and put back.0
Oh my goodness! We found a Doug!DougandMia said:We had the some idea, Photomom, but the bench wouldn't lay flat. It is amazing how much storage space there is back there. You never know what you might find.
Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”3 -
Yeah, my sleeping stuff goes back there, too. Bed is made in under 30 seconds.PXLated said:Jenn - Yep, just the passenger side. Sleeping stuff goes behind the upright bench - easy to pull out and put back.
Now you have photo proof that Doug can crawl underneath and pick up the leetle bitty things you accidentally dropped and rolled into the area. Muhahahahahaha!2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)2
Now if we could only figure out how to get him out of there.......Mia Hamilton, Ontario, Canada. 2015 T@B U, formerly 2012 LG 5-Wide Platform5
My favorite mod. Since I travel solo, sleep wheel-to-wheel, and have a memory foam mattress (2"), I like to keep the bed made. I can still ratchet the bed up 1 notch for tv watching or all the way for company with it still made. Having access to that area from outside for the essentials saved me from carrying so much stuff in my TV.
Moderator's note: photos edited for size.
Cindy with my 2015 MaxS (Puppy) and my 2015 Subaru Outback (Boo)2 -
I'm itching to do that mod. We usually leave the bed made, too much work to remake it.
I'd love to find a way to add a hatch to both sides.Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya0 -
Another mod I have seen done that I am itching for is to make the couch double hinged so that it can be lifted from the bottom for easier access to that space. Would be really nice to be able to simply slide my bedroll behind the couch and leave the couch up.
Sterling, VA0 -
I wanted to make sure the top surface was not higher than the boards that the sofa rests on when in sleeping position, but I also wanted to make sure that whatever I did was lightweight, removable, and didn't block any air flow. I initially thought of using wire shelving (e.g. Closetmaid) but the sizes weren't what I needed. So I constructed barriers from wooden dowels, spaced around 3" apart. The boards the dowels fit into rest on angle brackets that are screwed into the wooden 2x4s and other wooden parts, and secured by wing nuts so they can be easily removed if necessary.
Passenger side:
Driver side:
I have two 26x78 thermarests, two rectangular sleeping bags, two fleece bag liners, two full size bed pillows, and the two PVC bench extensions that I previously posted, in the space behind the couch back. And nothing will get into the area where the hoses and wires and potentially spilled Alde fluid are.
Very happy with this solution, but working in that space was very difficult!John and Henrietta, Late 2016 T@B S Max in Western New York6 -
The entire area under the passenger side of the rear bench is still open. We have the spare tire in there now but ultimately will use it for food storage.John and Henrietta, Late 2016 T@B S Max in Western New York0
There is still a little unused space under the dowel "shelves" but my arms aren't long enough to reach there for anything, so no loss!John and Henrietta, Late 2016 T@B S Max in Western New York0
Nice solution. I just happen to have some dowels kicking around, so I think this might have moved up on the project list!
As you have probably already noted, the space under the dowels on the passenger side is continuous with the area where your spare now lives. I use that space to store long items such folding chairs and awnings that I only need to access when first setting up camp. The other side is blocked by the Alde, but I'm sure I'll come up with some little-needed item I can cram into that space, as well.Photomom said:There is still a little unused space under the dowel "shelves" but my arms aren't long enough to reach there for anything, so no loss!2015 T@B Max S (320)
These are 3/8 inch dowels spaced approximately every 3 inches. I believe that is sufficient for the stuff I'm putting back there. If you have heavier or smaller objects you may want to adjust accordingly. I also have one screw securing the angle brackets to the wooden trailer framing, you could beef that up too if you are storing heavier things.
In retrospect I should have investigated removing the sofa back as it was very difficult working back there.
I was pleasantly surprised with how much space there is behind the sofa. Perfect for bedding.John and Henrietta, Late 2016 T@B S Max in Western New York0 -
3 -
Thanks Photomom for the inspiration1
I use the space under the wire rack for storage, too. With your set up, you would have to pull everything out when you make the bed, correct?
It is a closet wire shelf from Lowe's. It is attached with screws. Helps keep the mattress topper behind the sofa, protects the Alde plumbing and simplifies storage under bench on the passenger side.1
