I have a 2015 T@B Sofitel S that I plan on putting the Yakima rack on. I would like to put a roof top box on the rack to carry chairs, a table, hoses, etc. I realize that it will be a bit tricky with the slant of the box to get things in and out of, but I feel that it out-weighs the lack of storage for all of my 'toys' which are fairly small and light weight. The box itself weighs 30lbs, so I still have ~70lbs for stuff. Also, I don't want to put the box on the TV as I plan on leaving it on my trailer with all my stuff in it so I can just hook up and head out of town. Any one try this?
https://www.rei.com/product/826378/yakima-rocketbox-pro-12-roof-box
The trailer is small and bounces more than you think. Just with the spare tire in the basket (~40 lbs), I've had to tighten and re-align the bars to level them a couple of times in the last 4-5 outings. Not a lot of re-centering, but enough to drive this OCD person nuts (cm or so?). I've had Yakima racks on the roof of past vehicles and not had to retighten anything, so it's probably just the angle this goes on the T@B.
The instructions with my rack and basket rated the total weight capacity at 70 lbs total. Things change over time and this might not apply to your setup. Just an FYI.
Keep in mind that water weighs over 8 lbs per gallon. Five gallons of gas will weigh pretty close. That's about 40 lbs. The max capacity of the rack with spare is 70 lbs (unless recently changed). Also, the angle the rack is at is directly pointed upwards towards the sun. Anything stored on it will get direct light and since gasoline is a volatile liquid, it's going to expand and escape. It's the fumes that readily ignite, not the liquid. A half empty tanker is more dangerous than a full one (info courtesy of my CDL trucker friend). Keep in mind that tunnels (like the one under Baltimore Harbor) may be an issue when transporting containers of gasoline or other volatile fluids.
In the end, do your research for where you live and where you are going regarding containers, how to tie them safely to your vehicle and any road restrictions that you may encounter. People transport volatile liquids safely everyday.
May the flames from the bridges I have burned light my path going forward.
