A few interior mods
Photomom
Member Posts: 2,217
I have a long list of nearly 20 things I want to do to our T@B and started with a few interior, high value things.
The first was the cabinet spring mod, although it pained me greatly to drill into the beautiful cabinets.
Next I added command hooks for keys above the door, and also came up with a way to mount my Acurite fridge temperature monitor. There is a command product for everything; the picture hanging strips seem ideal for this.
I had noticed that the shower floor seems a little slippery, so I added these safety treads from Bed Bath and Beyond.
I am still thinking about what to do about the back shelf that new T@Bs are coming with. It is quite heavy but there is usable storage beneath it when the back of the sofa is down. My simple solution was to use a paint stirrer stick, shortened by about an inch. but it would be easy to knock out of place and then the shelf would bang your fingers. I am wondering if the spring mod would work, but I hesitate to drill into the shelf (3/4" plywood) itself unless I'm sure it will work.
Is there anything below the shelf?
I think the rear shelf will be too heavy for the springs. This would be a good place for either the struts that were shown here in the past couple of weeks (good for those who had to remove them from the upper cabinets), or even better would be two of those toy chest hinges that are used so children won't have the lids fall on them.Verna, Columbus, IN
It is a nice space, about 54 inches wide, 6.5 inches front to back, and 6 inches deep. There are two wood braces at about 18 inches and 36 inches, so you can't put anything long there but otherwise it is an open space. I would love to know what the designers thought people would use the space for since it is only accessible with the sofa back down. Maybe pajamas?John and Henrietta, Late 2016 T@B S Max in Western New York0
I would use it for batteries or extra cables.
I was thinking it would be nice for hiding expensive lenses and electronics, but it gets quite warm with the Alde on since the heat comes up behind the space. Probably too warm for battery storage with the heat on.John and Henrietta, Late 2016 T@B S Max in Western New York0
The T@b towel warmer.Photomom said:I was thinking it would be nice for hiding expensive lenses and electronics, but it gets quite warm with the Alde on since the heat comes up behind the space. Probably too warm for battery storage with the heat on.
3 -
Oooh!John and Henrietta, Late 2016 T@B S Max in Western New York1
Yeah, I would think it would be for "just in case" stuff. An extra set of sheets, an extra blanket. Stuff you wouldn't get out every trip, but want to bring just in case. Maybe emergency toolkit (ratchets, sockets, pliers, etc.)Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL0 -
I was looking at my rear space yesterday trying to figure out how to make space there. Yee ole woodworker.....thinking......thinking....have to preserve my scrollwork....thinkng.....Verna, Columbus, IN
Bed slats?
Not long enough. I cut the board into four pieces in order to be able to scroll easier with the 20" throat of the scrollsaw; needed the ability to have a shorter turning radius.jkjenn said:Bed slats?
I could attach cleats on the underside of the board or just make separate lift tops for separate sections. I like the idea of a T@B towel warmer!Verna, Columbus, IN
No, because of the braces that run from front to back, nothing long will fit. I assume those are functional and shouldn't be removed. Plus it would be a shame to put the rough slats into a nicely finished space. @Verna let me know if you want any detaied measurements or pics.
John and Henrietta, Late 2016 T@B S Max in Western New York0 -
I put rails on mine and used it for canned and boxed goods. Found I didn't need to carry that much stuff so is empty at the moment.1
Thanks, Photomom. I would have to build the bottom and sides and dividers. Sort of "play it by ear". I would allow for a slot at the rear for the heat and my scrollwork would allow excess heat to vent from the storage. I like the idea of small stuff storage--I always have little things that need a dedicated place. Cords, pens, pencils, small pads of paper, etc. I need to see if a mirror on the rear wall will allow me to see the glycol level in my reservoir, too.Photomom said:No, because of the braces that run from front to back, nothing long will fit. I assume those are functional and shouldn't be removed. Plus it would be a shame to put the rough slats into a nicely finished space. @Verna let me know if you want any detaied measurements or pics.Verna, Columbus, IN
Remember, anything back there needs to be secured as it's the bounciest place on the inside. My canned goods (generally) stayed in place but the lighter stuff wouldn't without netting or something.0
So, no beer, then.John and Henrietta, Late 2016 T@B S Max in Western New York2
I wouldn't want to be close when you opened them der beers after being shakin up.0
Husband suggested using that space as the T@b slow cooker if the alde is on. So many possibilities! Each compartment for a different dish.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus.0 -
Rare earth magnets--a wonderful thing to have on handPXLated said:Remember, anything back there needs to be secured as it's the bounciest place on the inside. My canned goods (generally) stayed in place but the lighter stuff wouldn't without netting or something.Verna, Columbus, IN
I suppose they'd hold the canned goods in place. :-)0
Very nice mods Photomom! When we bought our CS, we thought our dog would love to sleep on the cushion on top of the front cabinet. But, after our first trip we found that he insisted on sleeping in the bed with us! Using that cabinet for clothes didn't work too well. So, we were looking for something better. We found these at Ikea. They are the Nordli 2-drawer cabinets. The base and top can be for a single or double unit. In hindsight, the double top would have made a better fit, but we originally planned to have them on both sides with a space in the middle. Only change was to screw the original cabinet lids down and then bolt the Ikea cabinets to the lids. Even after bouncing down I-75 in Ohio this weekend, nothing was out of place and always easily accessible!
Steve
West Chester, Ohio; 2015 Sofitel CS; 2015 Ford Escape5 -
Nice! Very clean looking and efficient.
:) Beth, 2015 Toyota Tacoma (Ramblin' Rose), 2014 T@B S M@xx (ClemenT@B)0 -
@Slange nice! What is the monitor next to the shower door?2016 T@B Maxx CS-S following a 2008 4Runner Ltd
Be brave. Take risks. Nothing can substitute experience.-Paulo Coelho0 -
I got these at the dollar store. They clip on the frame above the window and you can then hang your lantern on them. Works well. Still have to figure out a interior screen add on to help keep the bugs at bay that are attracted to the lights...
Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI0 -
Cool. Where would I find something like that - have only been in dollar stores a couple times and found them very confusing.TerryV6 said:I got these at the dollar store. They clip on the frame above the window and you can then hang your lantern on them. Works well. Still have to figure out a interior screen add on to help keep the bugs at bay that are attracted to the lights...
Most dollar stores have a section of laundry items, mops, racks, etc. at the end of the aisle that has laundry detergent. If you can navigate the clutter, they often have cheap, useful items. I have also found similar items in the hardware section at Wal-Mart, even some metal ones if that is to your liking.
The multiple-hooked hanger on the left in this photo is a modified tie rack I found at a dollar store, and the magazine/book rack on the right is a modified basket I found at Wal-Mart.
NomadPilgrim The monitor is a temperature/humidity gage from RadioShack. I bought the T@B tank monitor system but have yet to install.Steve
West Chester, Ohio; 2015 Sofitel CS; 2015 Ford Escape0 -
Hey! We're in West Chester too! Thought I'd reach ot and say Hey! lol
Sug@rsh@ck - 2016 Max S Outback, 2016 Nissan Pathfinder.0
- 956 Air Conditioning & Refrigeration
- 920 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
