general newbie electrical questions...12volt / 10-30-50amp???
ChanW said:Hmmm. There have been others that had problems at higher altitudes.
It works ok below 8000 feet? I had intermittent problems with the thermocouple connection coming loose at the controller, under the stovetop. It actually got worse at higher altitude, but that might have been coincidence. I finally used a bit of locktite to secure the connection. It has worked good since then, although I haven't had an opportunity to try it at altitude since.
@ChanW when this happened, we're you still able to light the fridge on LP or did the green light not come on at all?2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
When the thermocouple was loose, the fridge wouldn't light at all.
Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya0 -
We have no power on our Jensen tv! Won't turn on with the remote or with the on button on the tv.
Any suggestions?
There is a small fuse in the power line from the wall going to the television. Check that first.2016 Outback 320
Thanks, will do!0
- 427 Service/Maintenance & Recall Notices
