general newbie electrical questions...12volt / 10-30-50amp???
2»
  • jkjenn
    jkjenn Member Posts: 6,425
    ChanW said:
    Hmmm. There have been others that had problems at higher altitudes.
    It works ok below 8000 feet? I had intermittent problems with the thermocouple connection coming loose at the controller, under the stovetop. It actually got worse at higher altitude, but that might have been coincidence. I finally used a bit of locktite to secure the connection. It has worked good since then, although I haven't had an opportunity to try it at altitude since.
    @ChanW when this happened, we're you still able to light the fridge on LP or did the green light not come on at all?
  • ChanW
    ChanW Member Posts: 3,168
    When the thermocouple was loose, the fridge wouldn't light at all.
    Chan - near Buffalo NY
  • Lawrence
    Lawrence Member Posts: 2
    We have no power on our Jensen tv! Won't turn on with the remote or with the on button on the tv.
    Any suggestions?
  • Tabaz
    Tabaz Member Posts: 2,420
    There is a small fuse in the power line from the wall going to the television. Check that first.
    2016 Outback 320
  • Lawrence
    Thanks, will do!
