Has anyone used a pressure washer to clean their T@B? I know the owner's manual warns against using one on the graphics, but what about general cleaning?
Do not pressure wash the silicone caulking is what I was told. I just use a hand mitt on what I can reach and a long-handled RV brush on what I can't reach.
Verna, Columbus, IN 2021 T@B 320S Boondock “The T@B” Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”
I've pressure washed mine several times but am careful not to hold the sprayer in any one position for a long period of time. I think it also depends on the power of your pressure washer.
I just got a pressure washer for stripping fifteen years of paint and crud off my wooden deck. I haven't tried it on a vehicle, but being pretty lazy when it comes to washing stuff, I probably will.
You would want to use the tip with the widest possible spray pattern and keep the wand a couple feet back from the surface (at least to start). This allows the stream--and the pressure--to disperse.
As TABalong said, the power of your washer is also a consideration. Electric units operate in the <2000psi range and are mostly intended for light duty washing of cars and campers. Gas units can top 3000psi and will require more caution on the part of the user.
Regardless of what you do, I reiterate Verna's advise about staying away from any calking, as even modest pressure could peel this up. I would probably also avoid spraying the underside for fear of damaging the tar paper like undercoating, or any of the various plumbing and electric do-dads.
2015 T@B Max S (320) 2015 Nissan Frontier SV V6 4x4
