I have a "new to me" 2015 M@x-S. I have it connected to 110v/15a shore power, and nothing is being powered in the trailer (no outlets work, no AC power to either the refrigerator or air-conditioning unit, battery is not being charged). I have checked that there is electrical at the power cord, all breakers are in the correct position. Systems are working well under battery power.
Is there something I am missing, or can you suggest where I should begin to look?
Thanks is advance as I am new to this.
0 ·
May sound stupid but a bad 30/110 adapter had me running in circles once.
All this stuff is under the drivers side bench. The main cable is easily recognized because it's the only one that is orange. The connections, however, are buried within their respective devices. Forgive me if I'm stating the obvious, but operating on them requires a rudimentary understanding of AC electrical systems (starting with turning off the power).
Good luck and please let us know what you find!
Do you think it is possible I am not getting enough amps from the particular outlet to power the trailer? If so, do you know the minimum amount required? I would switch to another outlet, but this is the only accessible one at my house.
I'm not too concerned as I plan to mostly dry camp, but my curiosity can't let it go.
I'm starting to think it has to do with the connection between the female cord and male T@B receptacle as there is no power at the interior orange wire coming from the receptacle to the breaker.
Durango, CO
2015 S Outback
