http://tab-rv.vanillacommunity.com/discussion/comment/3852/#Comment_3852
Here is a previous discussion about an inoperable Norcold. Looks like there are three fuses on top of the unit. The stove needs to be removed to access them. Just search "Norcold Fuse" for more links.
That is interesting. I have tried different temperature settings, to no avail. I have not shut it down, altogether for a bit, so maybe I will try that soon. The fridge is getting low on content, so this weekend might be a good time.PXLated said:My fridge goes into "what the heck" mode every once in awhile. I shut it all down and start over. It usually goes back to normal but I have had it do this for 2-3 days. It's also flaky on the temp dial. Sometimes it cold at 3 , othertimes at 4 or 5. Sometimes when it's in flake mode, 5 makes it warmer.
So, before you start tearing into things, start over and try different setting ps on the temp dial.
AND - Did you install the fridge exhaust fan yet? If not, do it.
Wondering if the additional air flow would increase O2 availability to the Propane burner, especially for higher altitudes.PXLated said:Mr_Mrs_Gnome - Not really a recommendation, just an observation and what I found with mine and what I do on those occassions.
