First time de-winterizing experience
We haven't flushed and filled our camper as of yet... Darn newbies... I'd been doing some reading and have all the manuals.  I said I was going to do it today.  So, I came home from a doctor visit to find my wife on the phone.  She had compared the pics from the older Winterizing PDF, and saw our 2016 setup was different.  She decided to call our dealer, and he said he'd call back.  Like earlier experiences with them, no such luck.  So, Jody called Pleasant Valley and talked to a nice guy named Marvin, who explained the steps and also sent us the updated manual and the how to pdf.  Needless to say, all went well, and the stress levels are better too..
2016 NuCamp 320 T@B Max S
T@bbey  Road
Appleton,  WI
  • Verna
    Verna Member Posts: 6,876
    Marvin is a great and patience young man!
  • Photomom
    Photomom Member Posts: 2,217
    If you happen to have before and after pics showing the valves I would love to see them. I for one cannot make sense of the tubing layout.
  • TerryV6
    TerryV6 Member Posts: 1,101
    Do you have the 2016 Winterizing doc?  There is a before and after pic in there that matches the current layout.  Then it's easier..  Not sure if you can get it here, but I have the newer manual too.  Happy to send it your way...
    T@bbey  Road
    Appleton,  WI
  • Nomad
    Nomad Member Posts: 7,209
    TerryV6 - Any chance you could post it here?
  • TerryV6
    There you go guys..
    T@bbey  Road
    Appleton,  WI
  • TerryV6
    Speaking too soon Photomom...  We thought we'd filled up the fresh water, adding a little bleach as the info says.  Figured we would let it sit overnight.  This morning we ran the sink and shower, then emptied the gray water.  Got about two gallons back.  My sink lines were spitting, so I thought I was empty.  Thus we went plan B, and filled the tank manually, getting about 9-10 gallons in, allowing for spillage and shoe cleaning.  Ran the pump, turned on the sinks and only got minimal back.  So... back to the site here to do more searching.  I saw threads about blockage on the air line by the manual fill area..  I included a photo.  That would cause perhaps a fill problem, not  a usage problem.  I continued...  Next, someone said something about looking underneath, but my camper does not appear to have anywhere it get inside that way.  I then looked in the shower, behind the toilet, as per another discussion.  Here I found a disconnected line to the pump, the one on the left.  I included a pic of this from the manual.  That is the hose fitting for the intake side of the pump, or so it says.  I connected that.
    Still just getting spitting noises.
     I may have two problems...  One, a airline block not allowing my water hose to completely fill er up.  Now I might have created an air block for the pump to pull up the water from the tank..  I suppose I could run the pump with the sinks open and hope to water eventually...
    T@bbey  Road
    Appleton,  WI
  • Nomad
    Is something blocking the air/overflow line?
  • TerryV6
    Thats why included the picture..  It does look that way.  I wasn't going to poke or pull on it without further investigation and reassurance that I should...  I've done that with other things, but this costs a lot more...
    T@bbey  Road
    Appleton,  WI
  • Photomom
    mine looks like this, and sure enough when I filled the tank water squirted out of that hole so I know it is open.
  • ChanW
    ChanW Member Posts: 3,165
    If you can, stick your camera-phone (or a little mirror & light) in the cavity behind the toilet to be sure the vent hose is connected on the back of that filler fitting (and follow the hose as much as you can to look for kinks, while you're at it).
    That hole should be opened up if there's a hose on the back of it. Ours has no hose, so I've plugged that hole to keep water out of the wall.
  • ericnliz
    ericnliz Member Posts: 4,437
    TerryV6,
    Just wanted to say thanks for the helpful info you have given. As new T@B owners ourselves, any info is greatly appreciated! Keep it up! :)
  • TerryV6
    Thanks Eric,  I am such a newbie on all of this.  Usually, you can buy a product, say a bicycle, get on it, and ride away.. This is quite a learning experience, and I am trying to share my stupidity, errr easily made mistakes, with people.  That being said, this is what I've learned... First, my hose on the pump "was" disconnected.  I didn't do that, so it wasn't my fault.. I fixed that potential problem...
    Now, on to what was my fault.  First, I have read the manuals, but sometimes your mind goes down the wrong path.  For us, for some reason, don't ask me, we assumed the hose connection and the manual fill were two ways to fill the tank.  So, with the hose connected, we got plenty of water in the sink.  Once disconnected, not so much.  This was clouding the issue for us.
    Be clear though, there was still a problem here..
    Continuing, We then filled manually thru the other one, adding bleach this time, and got in 10 gallons.  But, same problem...   We did this yesterday of course, and it was raining, so I have that in my favor.  But, this morning, my wife then mentioned that Marvin had talked about a drain cock over by the steps, but said it was something we need not bother with.  I went to take a look.  The cock was open, and since the camper is near the edge of the driveway, it must have drained the fresh water out there into the grass.  There were a number of dead worms around there...
    I closed the valve, and now understanding where I was supposed to fill the tank, duh..., I did it with the hose and heard the unmistakable gurgling that people talk about..  Tada.....  we are in business...  If that drain line is in the manual, sorry, I missed it.  I did find the unhooked hose because of this.  Our pump sure can get noisy though....  Hope this helps others who are in the search for knowledge...
    There is confusion happening here...
    What it is, ain't exactly clear...
    Theres a T@b in the driveway over there,
    Telling me, I got to go somewhere...
    T@bbey  Road
    Appleton,  WI
  • TerryV6
    Anyone want to go fishing?
    qq.jpg 218.6K
    T@bbey  Road
    Appleton,  WI
  • ericnliz
    Terry,
    If it's calling to you----GO! ;)
  • TerryV6
    It's time we stop, say, what's that sound...
    Everyone is traveling round...
    Sorry Buffalo Springfield....
    T@bbey  Road
    Appleton,  WI
  • ericnliz
    What's funny, is that I know that one! :o
  • Ratkity
    Ratkity Member Posts: 3,770
    Terry, you still may have trapped air in the pump chambers if the pump sounds like a jackhammer. There's a mention in one of the many "loud jack-hammering pump" threads about air trapped in the chambers can cause it to rock and roll against the wall.
    Someone's solution was to actually suck the air out of the sink spigot. I had to sedate that one bad brain cell when I read that at 6am! :blush:
    Anyhow, my solution was to unhook the output line (one on the right) of the pump and turn on the pump - catching the water in a container. After a cup or two went through, I reconnected the line. The pump has been decibels quieter since. I know I'll have to do this again after re-winterization and blowing air through the lines so parts don't freeze. BTW, putting insulation around the pump didn't help... getting the air out did!
    Did someone mention fishing? *perk* Pass on the dead wormies. Mah fish like fresh wiggly ones!!
  • ericnliz
    Thanks for the info Ratkity! I bookmarked this for future ref!
  • Ratkity
    Yup, the fish like the wiggly worms! :wink:
  • ericnliz
    Not the worms silly, your solution for the trapped air! [Unless it was worms causing the clog!] =)
  • Ratkity
    edited June 2016
    :lol:
  • TerryV6
    It takes a village...... :)
    T@bbey  Road
    Appleton,  WI
  • ericnliz
    Or a worm farm! =)
  • TerryV6
    I'll try the pump idea tomorrow... Thanks....
    T@bbey  Road
    Appleton,  WI
