OK, this might fall under the category of DUH.
2012 Max Q has a furnace, and it has a Dometic "Cool Cat" heat pump (model is 441003.701). That'd be two different heating systems, right? If true, is it so that when connected to shore power, you're not burning propane when heating the trailer?
                0 ·
Dunno about the other question though.
The heat pump is not much good below 40, I use a small space heater instead.
Sterling, VA
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
