What the heck is that little tank for?
WildRumpus
Member Posts: 46
You know the little door that's right behind the toilet? I opened it and peered into it today. There's a tiny little tank in it that looks empty right now and has a little overflow hose coming out of it. What the heck is it? Reminds me of the little overflow tank next to a radiator.
Gainesville, FL
_____________________________
2016 CSS 320
2022 Tab 400 Boondock
2021 BMW X5 45e Plug In Hybrid
2016 CSS 320
Sounds like your Alde fluid expansion tank. It should have Alde glycol up to the 'minimum' line.
Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya1 -
Yep - As ChanW says - Dat be it.0
It may have fluid in it. Put a flashlight behind it to check the fluid level. Several people have overfilled it thinking it was empty. The Alde fluid is a light-colored green that is a little hard to see through the plastic.
Should be a little above the Min line - the manual says how much.
Question - when the Alde tank is behind that door, where do they put the water pump?John and Henrietta, Late 2016 T@B S Max in Western New York0 -
WildRumpus, What year & model is your trailer? Thanks2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf0 -
OK, it's the Alde fluid tank. That would explain the green liquid that seems to always appear on my driver's side stabilizer. I haven't used the heat yet on my 2016 CS-S since I've only owned it in the summer months. Is it normal for a little overflow to drip on the stabilizer like that?Gainesville, FL
2016 CSS 320
No - It might if the overflow tank is too full though.0
The Alde also supplies hot water, so if you use hot water, the Alde has to heat up, which would heat up the glycol. (Or at least that makes sense to me.)Verna, Columbus, IN
Sure about that Verna - Thought the glycol was just for heat and for hot water the Alde heat that directly.0
The glycol solution within the Alde is heated when you turn on the hot water. The difference between heating water only and running the "heat" is that the pump that moves the glycol solution to the radiators comes on when you turn on "heat." So there would be some expansion within the glycol system when you heat the water.
gerry - Flintstone, GA - 2015 T@B S - 2012 Toyota Highlander2
