What the heck is that little tank for?
You know the little door that's right behind the toilet? I opened it and peered into it today. There's a tiny little tank in it that looks empty right now and has a little overflow hose coming out of it. What the heck is it? Reminds me of the little overflow tank next to a radiator.
Gainesville, FL
_____________________________
2016 CSS 320
2022 Tab 400 Boondock
2021 BMW X5 45e Plug In Hybrid
  • ChanW
    ChanW Member Posts: 3,171
    Sounds like your Alde fluid expansion tank. It should have Alde glycol up to the 'minimum' line.
    Chan - near Buffalo NY
    2014 S Maxx (ie: "320")
  • Nomad
    Nomad Member Posts: 7,209
    Yep - As ChanW says - Dat be it.
  • Tabaz
    Tabaz Member Posts: 2,420
    It may have fluid in it. Put a flashlight behind it to check the fluid level. Several people have overfilled it thinking it was empty.  The Alde fluid is a light-colored green that is a little hard to see through the plastic.
  • Photomom
    Photomom Member Posts: 2,217
    Should be a little above the Min line - the manual says how much.
    Question - when the Alde tank is behind that door, where do they put the water pump?
  • ericnliz
    ericnliz Member Posts: 4,437
    WildRumpus, What year & model is your trailer? Thanks
  • deputydog
    deputydog Member Posts: 103
         Chan W-    If it is the Alde tank, it MUST be filled with glycol for the system to heat.   Make sure its filled to proper level or the heat will not work properly.
    TV is a 2007 Jeep Liberty. Own 2015 T@B Maxx s/wet-bath white green. St. Clair Shores, MI.
  • WildRumpus
    WildRumpus Member Posts: 46
    OK, it's the Alde fluid tank. That would explain the green liquid that seems to always appear on my driver's side stabilizer.  I haven't used the heat yet on my 2016 CS-S since I've only owned it in the summer months.  Is it normal for a little overflow to drip on the stabilizer like that?
    Gainesville, FL
    2016 CSS 320
  • Nomad
    No - It might if the overflow tank is too full though.
  • Verna
    Verna Member Posts: 6,876
    The Alde also supplies hot water, so if you use hot water, the Alde has to heat up, which would heat up the glycol. (Or at least that makes sense to me.)
  • Nomad
    Sure about that Verna - Thought the glycol was just for heat and for hot water the Alde heat that directly.
  • USWildflowers
    USWildflowers Member Posts: 177
    The glycol solution within the Alde is heated when you turn on the hot water. The difference between heating water only and running the "heat" is that the pump that moves the glycol solution to the radiators comes on when you turn on "heat." So there would be some expansion within the glycol system when you heat the water.
