Un-winterizing T@B to go camping, I hooked up fresh water line to T@B attachment for fresh water. get constant stream of water from rear of trailer drivers side, from some type of draining tube? with pressure on, ex. camping hose continues to feed water. This has never occurred before, so I'm thinking I must have turned a valve near furnace, but do not recall doing so? Need suggestions for this Old School newer camper.
TV is a 2007 Jeep Liberty. Own 2015 T@B Maxx s/wet-bath white green. St. Clair Shores, MI.
ScottG. Followed your suggestion and yellow valve was down, closed. Thanks Maybe I'll call Factory?
Could you post a picture, and also tell us the year and model of your trailer?JOEnJanet said:I have an ALDE 3010-9300. I put on my pressure regulator, and turned on the water. now I am aware of the blue drain line that drains the water for winterizing but there are two large black hoses that come from the heater, one goes to the flue, the other has a T-Line that goes through the floor of the trailer before continuing to the back of the trailer parallel to the flue line. As soon as I turn on the water the water goes straight out this black hose T-Line. Is something broken or are my valve line ups incorrect? Can't get hot water until I get this fixed.
