Hi folks,
Primarily like to use the Fridge in boondock travel without electric access. Wanted to see if anyone had any thoughts that might help me trouble shoot this. Just returned from Tearstock where service guys were able to take a cursory look but were overloaded with mods and routine service work to take it far, so no progress, sadly. Here is the story:
2013 Q-Max, have put about 11,000 miles on the T@B over the last 5 months, and have gotten quite comfortable with the start process, the fantastic reliability of using my Norcold on propane, knowing that it takes a level platform to start, and gas in the tank, which seems to last forever.....
On day 14 of a recent 14 day trip (thankfully), I went to do my usual start up of the propane function after a few hours drive, parked level, fully charged battery, and plenty of gas, continuing to supply the stove. When I attempted to do the start of the propane fridge mode, the usual reliable green lite did not appear, and I was unable therefore to turn on the fridge in propane mode. I can hear the ignitor clicking from the outside, and I was able to test that the fridge will put a load on electric in DC and works fine in AC mode, subsequently used several days in that mode without a problem.
Unable to find any popped fuses in the converter box
Accessed the three fuses on top of the fridge from the side vent, and do not see a defect there.
(While I was at Tearstock, was able to have the service guys take a cursory look, had them put in the needed vent fan while I was there, but they did not have the time to do an extended troubleshoot on my problem. I assume I am out of Norcold warranty at this point.)
Functionally it seems to me that there is something about the delivery of gas/spark that is not happening to allow the propane mod; Is there anything I am missing? I am probably not comfortable going further being the covers of the fridge unless there was something fairly obvious and easy to go after. I really hate to give up the notion that I can boondock for weeks on propane.
I am assuming this leads me to search for an Norcold authorized servicer to continue the trouble-shooting in Syracuse, NY area.
Thanks for any suggestions. Dave
0 ·
It sounds like your gas is not flowing to the fridge.
I bought a spare replacement thermocouple, but sent it back when I figured out it was just a loose connection.
I did find a video about the Thermocouple and there is a way to check it out, Hope that helps!
In all cases the methodology was the same: the fridge was pre-chilled on AC, packed with cold food and ice, and not run on DC en route. It was level, I ran the gas to the stove first, and the igniter was clicking normally.
My only thought was that something needed to "settle down" after being bounced down the road, but that's a pretty weak guess. Additional ideas or insights are welcome!
If I forget to remove the covers before trying to light the fridge, it will behave as you've described.
So maybe you have some kind of blockage in the intake/exhaust ports.
What kind of covers do you use on the exhaust ports? I am suspect that you are on to something; the only environmental thing that was different that day, I was parked next to a barn with barn materials abundant makes me suspicious for insects....Have decided to go to a certified Norcold repair place next week; I think I have hit my limit...
I cut the bottoms off two 1gal maple syrup jugs, drilled a little hole in each, and screw them into the 'port'. I always make sure to remove the covers when travelling. I don't think they'd stay in place.
So I replaced the thermocouple, being careful to place it exactly as it had been, and the same thing happened. I'll point out that the original owner had never used fridge on propane.
Took it to a camper repair shop, and they told me the only problem was that the thermocouple was not fully seated into its receptacle. Has worked fine since. Sounds like it may have been that way since day one, but was never discovered until I tried to use it.
On the vent cover (Chan, I love your idea!), I took that apart last year to clean & inspect it, and found two small paper wasp nests in there. Probably didn't completely block it, but certainly didn't help, either. Another thing to check for!
Again, great idea, Chan- thanks!
http://www.bloomberg.com/news/articles/2013-01-02/the-great-canadian-maple-syrup-heist
