Thanks
qhumberd
Moderator
2015-S Max - Picked it up today.
Congratulations on your new Boy/Girl???? I am sure you are busy exploring things tonight. The larger water tank allows for more storage inside, which is a plus. I wonder, though, how well it is tucked up under the frame so as to not get hit by rocks or objects, etc.? I guess that remains to be seen. What do you think?
Feel free to post up questions and you work your way through the mechanics of your new T@B. It really is a fine, fine travel trailer, and I know you will love it!
Beth, 2015 Toyota Tacoma (Ramblin' Rose), 2014 T@B S M@xx (ClemenT@B) -
Congrats!!! A bolt on swivel jack to replace the factory one will solve the tailgate issue. They are about $30. and work very well.EnjoyNormNorm & Pat. 320 S Outback Utah or somewhere else.
Wanderoo - The fresh water tank didn't seem to hang down any further than the black water tank but I only spent a minute on my back when I was trying to figure out where the drain was located. I'll get a better look tomorrow and see if I can get a measurement and a snapshot.normfun - Yep, think that's what I'm going to have to do. It's either that or extend the tongue or hitch. I was planning on mounting the tire on one side and a tube for the dump hose on the other so I'll have to rethink that if I need to get a bolt-on swivel.
You'll love the opening front window. My '07 has that, and it's great for airflow. I didn't know when Little Guy would begin incorporating the opening window, but we heard it was coming. Enjoy your new baby
Crystal & Daisy, a yellow 2007 T@B Q previously towed by a 2008 Jeep Liberty, and currently towed by a 2016 RAM 1500. -
Congratulations PXLated - We spent our first night in our new T@B Max S Saturday. In searching the internet I found this: http://jack-e-up.com. It allows for removal of the tongue jack as needed. I don't have one but I am considering it as my tongue jack is scraping the sidewalk as I pull out. Camping World has this on sale for $40.00. Welcome to the group. PhotoJoe
PhotoJoe - That looks like just the ticket - Think I'm going to order one - Thanks!
Wanderoo - Here's some pics of the fresh water tank showing how it's mounted just in front of the axel on the door side...
And here's a picture of the T@B cutting board - Fits perfectly in the sink...
Congratulations! What fun new features. Enjoy!
Tiff in Seattle
2012 BMW x3/2008 TCS "Sunny"
Hi,I am hoping to get my T@B sometime soon, I was also wondering about the tanks and clearance underneath. Has anyone tried to put a skid plate underneath to help protect stuff? I also got the Jack E up and that solves alot of problems with clearance. You can just take the whole thing out.renThe Mouse house and me
Ordered the Jack E this afternoon - That seems to be the slickest solution.
Thanks for posting up the pic of the water tank underneath the T@B. It seems to be tucked up pretty good out of harm's way. That definitely would make a lot more storage room inside the T@B. Are you having F-U-N???? Does your new T@B have a name yet?
Well, the dealer didn't much so I spent the morning running around (getting propane, hooking up the Zap port, etc) that I really didn't get everything fired up and tested till mid afternoon. But, everything seems to work - sure takes the fridge a long time to get cold. Only found a couple of things wrong that I'll need to talk to Ed about.Gonna sleep in it tonight.I've never been one to name things so we'll see.
How about No N@me?
That would work :-)Or maybe Nom@dBut I thought you had to have the whole T@B in the name to be official.
There's always crawling underneath and looking but that would sure be a pain. Wish they'd have put in a level float (with remote gauge) or something when they moved it outside.
I've heard that (and experienced it as well), one person uses 1 gallon per day just for washing dishes, brushing teeth, and washing hands/face. If you take a shower or flush, you would have to guesstimate that until you get a good idea of how much that uses.
) Beth, 2015 Toyota Tacoma (Ramblin' Rose), 2014 T@B S M@xx (ClemenT@B) -
The mechanical and Alde setups are completely different in my T@B and since it was just born a couple of weeks ago it's probably the most current. Thought I'd post some pics of what's under each seat now.1 - Drivers side seat - Mechanicals2 - Drivers side back bench - Alde and related plumbing3 - Passenger side back bench - Note the Alde hoses - This compartment gets rather warm.4 - Passenger side seat - Wider open that before
Thought I'd post this pic showing the Alde vents as they are completely different than the models I had looked at. The models I saw had vents below the back bench and below the passenger side seat (maybe even the drivers side.Now, there are vents below the passenger side as before but the other vents are way in the back below that little shelf. One potential problem with that is if you have the back bench down for sleeping the bedding can cover up those back vents. Might have been better to put the vents in that shelf rather then on the front face.(Sorry about the really bad pic)
Hi, PXLated -- My 2014 S M@xx is the same as yours with two exceptions: I do not have the Alde cut-off water valve, and I do have the Alde vents below the back benches -- I also have a 110V plug below the back benches. I also have the Alde vents (below the little shelf), and I make sure the bedding is pulled out a little way so as not to block the heat. Usually, though, the T@B gets very, very warm with the Alde on, so I shut it off before I go to sleep. The coldest it has been when I am camping is 36 degrees outside, and I still shut the Alde off I was SO warm. Both of my side compartments look like yours.
Does your little shelf have screws on either end and a thumbhole in the middle? I took the screws out and lifted it up so I could look under it. That's where the glycol overflow tank is, and you should check the level of fluid to make sure it's not below the MIN level. Mine was just fine. I love the little shelf to put stuff on, i.e., box of Kleenex, clock, flashlight.
Have fun exploring!
>- Beth, 2015 Toyota Tacoma (Ramblin' Rose), 2014 T@B S M@xx (ClemenT@B) -
Wanderoo - Interesting, the ones I looked at (thought they were 14s) I recall differently - Maybe my brain's going.Yes, my back shelf has screws and a pull hole - Will have to open that and check the glycol. Am thinking about putting a 2-3" rail across the width and using it for canned goods, etc. - might look a little tacky when the back is down but that usually won't be the case unless I'm in bed. Would free up my other cabinets for other things.Slept in it last night (38) and had to turn the Alde down to the minimum.
Pxlated- to solve the problem of your rear hatch getting in the way of hitch, there is a solution.. Google jack-e-up. Recently found this and it looks easy to install and will purchase it soon, since I have the same problem when T@B is hooked to Tow vehicle.
TV is a 2007 Jeep Liberty. Own 2015 T@B Maxx s/wet-bath white green. St. Clair Shores, MI.
How does this Jack-e-Up thingie work? Does it actually remove the entire handle??? Anybody out there use one? Comments? :-/Beth, 2015 Toyota Tacoma (Ramblin' Rose), 2014 T@B S M@xx (ClemenT@B)
Wanderoo - Just got mine today, haven't installed it yet but it allows you to remove and reinstall the entire jack with nothing more than a twist - Twist and remove (put in TV), insert, twist and it's the fully functional jack again.
It sounds too cool to be true. Let me know how you like it and how easy it is to install. Camping World has them on sale for $40 through 11/2/14.
Thanks!
Got mine from Camping World - Was hoping to get it installed today but configuring my new MacBook-Pro was the most pressing (need to finish a job while I'm in Mpls) - Maybe tomorrow. Will report.
Wanderoo - Got it installed today - easy to do. I have mixed feelings about it. It works but as you can see in the photo it's really resting on the very edges of the triangular base of the jack. Seems solid once the weight of the trailer is on it and there's no way it can slip through but certainly doesn't look solid. If one could slip the JackUp plate down from the top of the jack column it'd be perfect but the crank on mine is welded on - That was my quick observation, I'll recheck that tomorrow, was under the gun today when I installed it.I'm going to go with it for now as I like it better than a tilt jack.One thing I had to do was use washers to space it up as it won't fit down between the hitch bolts - no biggy.
PXLated -- I think my crank is welded on, too. This picture reminds me of something I need to check on my T@B's tongue. I don't think I have those extra two bolts you have that the Jack-E-Up plate is resting on . . . :(Beth, 2015 Toyota Tacoma (Ramblin' Rose), 2014 T@B S M@xx (ClemenT@B)
Wanderoo - There's two on each side. If they were just 3/16th of an inch further to the side the Jack-Up would have just dropped right in.
- 916 Introductions
- 72 Teardrop Groups & Links
- 913 Tips & Tricks
