Can the Tent / Visor be put up on either side of T@B? I know it will go on front side where the door is. Just wondering if it can be put up on opposite side as well. Thanks in advance for your comments!
If I remember correctly, PopT@B made a modification to his keeder rail on the non-door side to accommodate a visor I believe. Used welding vise grips to open the keeder rail to make sliding the visor easier. Pretty slick modification.
2016 T@B MAX S-aka: WolfT@B TV: 2006 Chevy Avalanche LT Z71 aka: WhiteWolf, or 1972 Chevy Custom10 P/U aka: SnarlingWolf Spokane, Wa. Eric aka: Lone Wolf
There's full keder rails on both sides, but for reasons that remain unclear, the non-door sides don't seem to have an opening in which to slide the accessories. However, it's easy enough to create one yourself.
2015 T@B Max S (320) 2015 Nissan Frontier SV V6 4x4
Pop-T@B was kind enough to use his vise grip tool on my driver's side Keder rail so that I can use either combination of visor, awning or tent on either side (although I think the tent will only fit on the passenger side.
As Ericnliz says, you must make an entry place to start the Keder attachment for your accessory. Look at your Keder rails and you'll see the flatter section and understand better.
Verna, Columbus, IN 2021 T@B 320S Boondock “The T@B” Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”
2019 Ford F-150 3.5L Ecoboost with Long Bed
