Hello all,I have a 2014 cs-s with the shower and toilet,I haven't used the black tank since buying the trailer,I just noticed,the black tank drain is basically a elbow with a valve that is connected to the underside of the holding tank,well my elbow will swivel where it connects to the tank,just doesn't seem right,I am sure if there was liquid in the tank,the underside of the floor between the fabric and floor would get wet ,not good,Anyone know if this should be glued in place?
0 ·
Is it loose enough to completely remove so you can get a better look?
matt
PS .I did do all the factory requested sealing described in the above sticky thread,I did have more then one areas that did need caulking,so if you haven't done it yet,get out there,and get under your trailers.
