Don't forget the inline fuse to the CO detector and the GFI set/reset button on the outlet near the CO detector. The smoke detector takes a 9 volt battery (which was removed promptly after crisping bacon for the first time). Some air conditioners have a GFI set/reset button on their 110v plug (YMMV since there are so many AC models out there).OutbackAZ said:The "hidden" fuses (in addition to the main groups PXL mentioned above are (1) 30 amp in-line blade at the battery, (2) in-line blade fuse behind the television, (3) small blade fuse in back of the Jensen (need to remove it from the cabinet to access) and (4) glass fuse in the ceiling fan.
