Fuses -- I'm confused
Should I have extra fuses on hand, and where can I read about where they go and how to replace them?  Thank you.
  • Nomad
    Nomad Member Posts: 7,209
    Yes. There are several threads about the various fuses you need. Search "fuses" (upper right) and you'll get the skinny. There are three main fuse groups - main fuse box, Alde, Fridge. The first are standard automotive blade fuses found at any auto parts store. Most order the others online.
  • Tabaz
    Tabaz Member Posts: 2,420
    The "hidden" fuses (in addition to the main groups PXL mentioned above are (1) 30 amp in-line blade at the battery, (2) in-line blade fuse behind the television, (3) small blade fuse in back of the Jensen (need to remove it from the cabinet to access) and (4) glass fuse in the ceiling fan.
  • ChanW
    ChanW Member Posts: 3,171
    edited August 2016
    Ok, @OutbackAZ
    you've done some sleuthing here.
    I had no idea about the 'fuse behind the television' or the Jensen fuse...
    (Thanks!)
    Chan - near Buffalo NY
    2014 S Maxx (ie: "320")
  • Ratkity
    Ratkity Member Posts: 3,770
    Don't forget the inline fuse to the CO detector and the GFI set/reset button on the outlet near the CO detector. The smoke detector takes a 9 volt battery (which was removed promptly after crisping bacon for the first time). Some air conditioners have a GFI set/reset button on their 110v plug (YMMV since there are so many AC models out there).
  • Nomad
    Sorry... I keep forgetting about the fuses related to the media package - don't have it :-)
  • Tabaz
    There's an in-line fuse to the CO detector?  I missed that one.
  • baclawson
    baclawson Member Posts: 17
    oh my.  I have a lot of learning to do.  Thank you everyone!
  • ericnliz
    ericnliz Member Posts: 4,437
    It's all so conFUSING! Just bring spares, you'll be ok. =)
  • Tabaz
    I'll update the fuse inventory sheet this week unless someone beats me to it.
  • ericnliz
    Thanks OutbackAZ, helpful for the new folks here!
