Stabilizer Loose
jkjenn
Member Posts: 6,417
I recently sprayed my rear stabilizer with WD-40 to clean it, and now it slowly start to fall down while driving. Has anyone had this happen? Does it just require tightening?
Never had that issue, often I have trouble getting it started when trying to put it down. Are you giving it a good tightening when you put it up?
Also, for lubrication, I would recommend a white lithium grease, regular WD-40 is made for indoor use and will wash away in the rain. WD-40 actually makes a spray on white lithium grease that I have found works well. Use it on the BAL as well.
Sterling, VA -
Cyclonic said:Never had that issue, often I have trouble getting it started when trying to put it down. Are you giving it a good tightening when you put it up?
I was looking more to clean the unit and WD-40 is good for cleaning. I also carry white lithium grease to lubricate. I did not lubricate because it did not seem to need it. Maybe the answer is just a little spray with the garden hose.2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
I think this is good advice because I believe the screw mechanism on the BAL is cast aluminum, which will wear more easily than steel. Lubrication should mean less wear.Cyclonic said:... Use it on the BAL as well.
Have not yet had a problem with the stabilizer coming down, maybe because I do not keep it as clean and lubed as well as I should. -
I put a lot of effort into cleaning and lubricating the BAL this summer as it was exposed to dirt all of the time.
I quit lubing the stabilizers - just collects more dirt. Instead, I get under and hit them with a good wash and wire brush when needed.
I wrenched one of ours last year and had to replace it...piece of cake (4 nuts) with a an identical standard BAL stabilizer from our RV store. They come in pairs, so I have an extra...let me know if you want me to price out mailing it to you.
J.D. & Sue
- 916 Introductions
- 72 Teardrop Groups & Links
