Here are some photos that may help. Also, don't forget to check the air filter screen to insure it's clean.
http://tab-rv.vanillaforums.com/discussion/2709/how-to-remove-the-air-conditioner
And an other thing, SOME refrigerants are compatible with others, SOME are not, due to their chemical composition and the oil type that is blended in with the gas. Put the wrong two together and you'll have a real mess to contend with. DO NOT play with chemicals.JandJ92010 said:You must be licensed in order to handle most types of refrigerants, R-134A in autos, anyone can use. Older A/C's used R-22, new ones use R-410. Leave the charging of an A/C unit to the professionals.
JandJ92010 said:And an other thing, SOME refrigerants are compatible with others, SOME are not, due to their chemical composition and the oil type that is blended in with the gas. Put the wrong two together and you'll have a real mess to contend with. DO NOT play with chemicals.JandJ92010 said:You must be licensed in order to handle most types of refrigerants, R-134A in autos, anyone can use. Older A/C's used R-22, new ones use R-410. Leave the charging of an A/C unit to the professionals.
RollingLagrima said:
103 outside. 73 inside. 0939 hours. July, Lake Havasu, AZ. My 5000 btu is fine as long as I limit the amount of "coming and going" from the T@B and keep the shades closed.
