1. T@B is much more comfortable than a leaky tent.
2. Fridge is awesome on 120 and propane. On propane it really rocks, need to adjust temp from 120 setting or stuff will freeze.
3. Group 27 battery good for around 48 hours before recharging. Did figure out which fuses to pull to eliminate unnecessary parasitic draw.
4. T@B is not insect proof. See separate posting.
5. If you drive on a really bumpy road check the Alde 120v cord. Outlet is kind of loose and plug can come out.
3 ·
it should be noted that the amperage of some of my fuses don't match the chart so it's possible the wiring doesn't match either.
We'd be running the fridge on propane, so we'd need #1 and #4 (for the LP detector.) I'm not sure what the battery charger does in the unplugged scenario or if it draws any current.
I do want to test this but it got hot again and my T@B was 98 inside when I went out to make the picture. Maybe in a few days.
Pulling the battery charger fuse (#6) will effectively disconnect your battery from the camper. When running on battery, that's where the power comes in--the circuit only draws current when you are on shore power.
On our last trip I was able to turn the entertainment system blue light off in the settings. I use black electrical tape on the TV and fridge.
https://www.asaelectronics.com/downloads/dl/file/id/528/awm965_owners_manual.pdf
J.D. & Sue
