OK this might be a very dumb question once exposed to light but I was born blonde so I have a God-given right to ask a very dumb question at least once a year.
I'm in the middle of the cooling fans mod on our fridge and for some reason I can't get the fridge to fire up and run on propane. The range burners will light and stay burning at the same time the fridge wont. I was very careful when splicing into the fan wires so I don't think I broke anything ... I'm thinking it's a leveling issue - or low propane.
Anyway my question is would the fan(s) come on if the fridge is running on shore power or is it simply the LP mode burning of propane that causes so much heat to develop on top?
0 ·
Ok well as it turned out it wasn't low propane or leveling ... over the course of two days of racking my brain trying figure out why the fridge suddenly wouldn't light after installing the new fan wiring, wiggling every wire and connection making sure I didn't knock something loose with my fat fingers, I discovered that this connection on the safety switch thermocouple had come loose. It was barely finger tight if even that and the copper lead was very loose inside it. As soon as I tightened it the fridge fired right up on propane. Thank goodness this didn't happen on the road...sheesh.
We had the problem two or three times before I added a touch of Loctite to the nut. I think it's fixed now.
Given my own issues, I'll be checking mine when open up to install the fridge auxiliary cooling fan.
I thought it was due to vibration, but I guess you just have to look at it!
Something about Schrodinger's cat?
But maybe only when you poke on their nut, as ScottG did.
(Ok, sorry. Off topic. Still trying to find my second glass of wine...)
